figuring out that third dimension...but bracing_displacement is gettin on my nerves!
oh, I see. so the area from the upper right corner of the port (where it changes direction) is not included in the port displacement?
ahh, ok. I kept confusing the definition of internal depth as (external depth - 2 * MDF_thickness - port_width) when it's just without subtracting port_width.
man you's a killah! thanks a lot!
**** sumone ...that's worth 4-12 bucks in my opinion. Send JMAC some money bro....And this should be pinned for the valuable info it offers. If I save this do I have to send money too.....or just if I use it? lol
I've written up something to help myself understand...cause I know I'm gonna forget all this stuff in a week. It's only right that I use the help that I got to help others
here
since the gallery doesn't work I can't show that picture cause geocities makes sure that the referrer is blank or from them; but here's the text:
Based on instructions from Jmac (email/PM him for a CHEAP, fully COMPLETE box plan!)
...An L-shaped port's displacement....
1. Figure out theoretical Lv
Lv = Av*1.84*10^8/[Vb*1728*(Fb/0.159)^2] - 0.823*sqrt(Av)
Lv = Port Length in inches
Av = Port Area in square inches
Vb = Net Internal Volume in cubic feet
Fb = Desired Tuning Frequency
2. End_Correction = Port_width / 2.
Physical Lv, Lv_p, is Lv_p = Lv - End_Correction
3. Choose a number smaller than Lv_p and bigger than 2 * MDF_Thickness as a test depth of box (D).
- As viewed from top, D = vertical (external) length from front of box to back of box
4. Port wall P1 is interior length of the depth (P1 = D - 2 * MDF_Thickness)
P1_MDF_Needed is Port wall P1 minus the Port_Width (P1_MDF_Needed = P1 - Port_Width)
5. Port wall P2 is physical port length minus depth of box (Lv_p - D)
P2_MDF_Needed is equal to Port Wall P2 (P2_MDF_Needed = P2)
(Port_Wall_2's right edge connects to the top-left edge of Port_Wall_1, not the top-right edge of Port_Wall_1)
Displacement of port is:
(P1 * Height_of_Box * (MDF_Thickness + Port_Width)) + (P2 * Height_of_Box * (MDF_Thickness + Port_Width))
or
(P1 + P2) * Height_of_Box * (MDF_Thickness + Port_Width)
I tried to go through some algebra to get the port area/displacement including mdf in one line but didn't check it cause then Jmac responded and he's the "man with the plan"...
just to prove that I wasn't just in search of just an ANSWER, but a method to producing the answer, here's what I got before Jmac responded on getting port displacement (mdf included):
p + q = port_length, where port_length is an L-shaped port, p is the vertical component & q is the horizontal component (as if there were a line running directly center of the port)
q = port_length - p
x = p + p_width/2
y = q - p_width/2
where x is the interior depth of the box, and y is the width of the horizontal mdf needed (along with the mdf_thickness from the vertical component)
area_mdf_height = (x - port_width) * mdf_thickness
area_mdf_width = (y - mdf_thickness) * mdf_thickness
total_mdf_area =
(x - port_width + y-mdf_thickness) mdf_thickness
((p+p_width/2) - p_width + (q - p_width/2) - mdf_thickness) * mdf_thickness
((p + p_width/2) - p_width + ((port_len-p) - p_width/2) - mdf_thickness) * mdf_thickness
p + p_width/2 - p_width + port_len - p - p_width/2 - mdf_thickness) * mdf_thickness
((p - p) + (p_width/2 - p_width/2) - p_width + port_len - mdfthicnkness) * mdf_thickness
(0 + 0 + port_len - p_width - mdf_thickness) * mdf_thickness
= (port_len - p_width - mdf_thickness) * mdf_thickness
total horizontal area (extending all the way to the right wall)
(port_width) * (Y + Port_Width)
total vertical area
(X - Port_Width) * (port_width)
therefore, port area excluding mdf is:
total port_area =
(port_width) * ((y + port_width) + (x - port_width))
((q - port_width/2) + port_width + (p + port_width/2) - port_width) * (port_width)
((port_len-p - port_width/2) + port_width + (p + port_width/2) - port_width) * port_width
(port_len - p - port_width/2 + port_width + p + port_width/2 - port_width) * port_width
(port_len + (-p + p) + (-port_width/2 + port_width/2) + (port_width - port_width)) * port_width
= port_len * port_width
total mdf area with port area:
(port_len - p_width - mdf_thickness) * mdf_thickness) + (port_len * port_width)
port_len*mdf_thick - p_width*mdf_thickness - mdf_thickness*mdf_thickness + port_len*port_width
= (port_len - p_width) * mdf_thickness - mdf_thickness^2 + port_len*port_width
port_len = 18.786
p_width = 1.75
mdf_thick = .75
= 17.036 * .75 - .5625 + 32.8755
= 45.09
45.09 multiplied by the height 15" = 45.09 * 15 = 676.35
port_len = 18
= 16.25 * .75 - .5625 + 31.5
= 43.125 multiplied by 15, = 646.875
compared with Jmac's 618.75, I'd say I was kinda close //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
This ain't over, I'm gonna figure out what it is I was doing wrong...
It's over: I got it:
going backwards, (knowing what the final displacement is, and solving for port_length),
((port_len - 1.75) * .75 - .5625 + port_len * 1.75) * 15 = 618.75
41.25 = (port_len - 1.75).75 - .5625 + port_len*1.75
41.8125 = (port_len-1.75).75 + port_len*1.75
= .75port_len - 1.3125 + 1.75*port_len
43.125 = (.75 + 1.75)port-len
43.125 = 2.5port_len
17.25 = port_len
this 17.25 is actually the distance of the port excluding the front opening of the box. the forumlae I came up with all had to do with the inside of the box.
therefore, with an Lv of Lv_Theoretical,
Port_length_For_my_stuff = RoundUp(Lv - port_width/2) - MDF_thickness
port_length_for_my_stuff = RoundUp(18.786 - 1.75/2) - 0.75
port_length_for_my_stuff = 18 - 0.75
= 17.25
so to sum it up, the displacement for an L-shaped port is:
((internal_port_len - p_width) * mdf_thickness - mdf_thickness^2 + internal_port_len*port_width) * internal_height_of_box
where:
+ internal_port_len = RoundUp(Lv - port_width/2) - MDF_thickness
+ Lv = theoretical port length (Lv = Av*1.84*10^8/[Vb*1728*(Fb/0.159)^2] - 0.823*sqrt(Av))
+ p_width = port_width
+ mdf_thickness = thickness of mdf (.5, .75, 1)
+ internal_height_of_box = self explanatory
just to check,
internal_port_len = roundUp(18.786 - 1.75/2) - .75 = 18 - .75 = 17.25
p_width = 1.75
mdf_thickness = .75
internal height_of_box = 15
((17.25 - 1.75) * .75 - .75^2 + 17.25*1.75) * 15
(15.5 *.75 - .5625 + 30.1875) * 15
(41.25) * 15
= 618.75 in^3
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
so now that I got the displacement, adding all displacements up & net_volume, then dividing by the already known two dimensions gives you the third internal dimension. Round this up.
Therefore, the port walls will be:
vertical port wall: (internal_depth_rounded_up - port_width) x MDF_Thickness x internal_box_height
horizontal port wall: ((internal_port_length + MDF_thickness) - external_depth) x MDF_Thickness x internal_box_height
Thanks Jmac!!! couldn't have did it w/o you!
****, and school ain't even in session //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
sumone
sumone
Midwest
sumone
