Fiberglassing part of dash???
lspin01l
I have a 97 Dodge Dakota. I got XM radio for x-mas and I have already installed it. I got the SkyFi2 reciever instead of the direct link to my alpine head unit. I figured it would be better than just having an eight character display. Right now, I have it attached to my air vent above my head unit, but I think it looks too bulky. What I would like to do is fiberglass the piece of the dash under the headunit/air controls/etc so it would fit flush with the dash. What would the level of difficulty be, and how would I go about doing it. I have read over the fiberglassing how-to's and they have helped a little bit, but there isnt much on this type of stuff. Also, is there a type of paint that would match the rest of the dash??
I haven't done any fiberglassing before, but I have installed all my other equipment, so I am pretty comfortable with the basic stuff... Installing head units/speakers/amps/subs etc.
Thanks for any and all help
ok, hopefully I have figured it out...
The red outlined piece can come out, and thats what I'm looking at to replace with a custom fiberglassed piece. The Blue part is the approximate location to where I would put the radio.
I looked through that site, it and had some pretty cool stuff. I guess what I'm thinking of doing is making an entire piece of the dash (the red outline) with a spot for the XM unit. Kinda like he had the monitors, flush with the rest of the car. What would be the best way to go about this? I had an idea to mount something (like a mdf ring, but for the XM unit) and put fleece over it, using the original piece as the "back" of the "box." I would not, of course, fiberglass the new piece to the original, but use the original as some sort of guide until I got enough of a mold to work with.
My dad had an idea to use chicken wire to make a mold, and then going from there. Would this be a bad idea??
If you have any ideas please suggest them to me.
PS. Sorry if I dont make any sense, Im trying to explain it the best I can...
I have decided to make sort of a sub box, but without a back so it fits on the dash. I hae made a trim ring for the XM unit, and will probably start fiberglassing tomorrow...
ok, how about this.
use the origional piece, and get some PLASTIC bodyfiller, the 3M 40\40 stuff will work quite well. then you stick the XM unit to the plastic thing on your dash, and mould the plastic filler around it like you would do bodyfiller, until your shape is created. sand down, a light layer of skim coat, and then mask the XM unit, then paint the piece, and re-attach it.
but just FYI, fiberglass resin and\or bodyfiller is not meant for plastics. i learned this a few days ago (sigh) and hopefully mine will stay attached, but you really never know.
if you wanna make the whole thing seperate with fiberglass and resin, then try using a very thin material, such as an old Tshirt or some speaker grill cloth when you stretch it over the mould.
a good tip is to cover that entire dash trim piece with a few layers of aluminum foil and\or masking tape to keep the resin from sticking to the origional piece of the car.
never put the fiberglass on the outside of the mould you make, only apply it to the inside that you cannot see. saves ALOT of sanding time.
and also- SAND DOWN THEM EDGES! take that baffle-ish thing you made for your XM unit, and make those edges nice and round. as symetrical as possible. make sure you AIM the XM unit toward the driver seat so it is eaisly visible when driving also. and use hot-glue to secure the grill cloth on the BACK (stretch it all the way around) the plastic dash piece. once the mould has dried, try to cut the back glue points off the mould so you keep the nice edges. this piece is NOT a structural piece, so it does not have to withstand bullets.
use matte black SEM brand "satin black" spray paint. spray from 10~20 inches away for texture, then do a regular black coat. it should look perfect.
did that clear it all up?
Its clearin gup a bit. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I hope to go get the stuff for fiberglassing tomorrow, and possibly starting on it. I havent felt good today, so I didnt do anything, but I may start on it tomorrow. Hopefully, I get it done before I go back to school on Monday, because I have a tough semester coming up along with longer baseball practices and will have very little time.
Thanks for all the help so far, I will try to keep you updated.
ummmmk. I think I am going to start on it today. I took the piece out of my truck and it looks like it will be a little bit more complicated than I first thought. I am looking to replace this piece with a fiberglass piece that looks stock, just with the XM unit built in. If Im not mistaken, all I need out of this piece is the outside form, so the new piece will fit back in its spot.
This is the approximate place that I will have it, facing somewhat towards the drivers seat, obviously not the ground...
This is the backside of the piece, I wont need to worry about anything for this will I???
to be honest, id move that over to the left a little more so ya dont have to bother taking out the ashtray and re-glassing it over.
then just sand the area you are going to work on, and cut out the inner shape of the wood part to the plastic.
attach the wood part with some gorilla glue\resin\whatever and then use PLASTIC BODY FILLER to attach the wood to the ABS dash piece. CAR\METAL bodyfiller should NOT be used. then just sand\paint and re-install the XM unit. good luck.
check http://www.the12volt.com/installbay or http://www.hzemall.com - he uses that blue stuff (3m 40\40 plastic filler stuff) not bodyfiller. i think its called 'duramix 40\40" or somthing.
http://products3.3m.com/catalog/us/en001/auto_marine_aero/automotive_aftermarket/node_ZWH06WLVRFbe/root_GST1T4S9TCgv/vroot_GSLPLPKL4Xge/gvel_DDC4KLKK5Wgl/theme_us_aad_3_0/command_AbcPageHandler/output_html
there ya go. thats what you need to work with plastics.
http://products3.3m.com/catalog/us/en001/auto_marine_aero/automotive_aftermarket/node_P4J83NXTR3gs/root_GST1T4S9TCgv/vroot_GSLPLPKL4Xge/bgel_HFK6WGW3W8bl/gvel_DDC4KLKK5Wgl/theme_us_aad_3_0/command_AbcPageHandler/output_html
but that crap dries REALLY quick, so you gotta use it quickly.
I wouild move it to the left, but it is a manual transmission, and the stick would be in the way if I moved it to the left. That was the only place that I had full vision at all times.
hmm. i see. so you would have to loose the ashtray then. not a problem. see if you can find some ABS plastic panels, and just kind glue them in place over the hole of the ashtray... or use the actual ashtray front and just fill the gap made.
you will wan to remove all the stuff behind the ashtray though.
but i seriously recommend using the ABS filler compared to regular bodyfiller. ill try and find a cheaper alternative to the 3m, but i KNOW that the duramix works.
lspin01l
lspin01l
Atlanta, GA
req
