fiberglassing a false floor
i think he's trying to do some sort of false floor/speaker enclosure, with the subs inverse mounted onto it, if i understand what he's saying, so flexible wouldn't work
you could do plexi, if you wanted..
at the local shop here someone mounted a 13W7 under the passanger front carpet (where ur feet usually are) they made a really small sealed box and did alot of cutting than just put a good grill over it and covered it with the carpet, it sounded differnt cuse the bass was actually coming from in front of u.
Edit : I didnt realy ur post correctly, u can probably do it pretty easily, like tehy said just use plexi glass or somethign over the top and make a small flat box.
I can help you with that
you are local.....kinda
birch on the floor, glass in the tire well, birch walls, and subs inverted, and glassed countoured however you want..........witha slot port (2 4's on 2 12's is very small imo)
or maybe 2 sixers, or an eight.
fakename
fakename
earth
iamamp3pimp
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
