Fiberglass Icing
SSplaytoy
I read about an "icing" that makes a fiberglass box a lot easier to sand and much easier to work with than bondo. But it was only refered to as icing???? //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
What would be good to get the box really smooth without sanding for a hundred years?
"Icing" is just finishing putty. Go to any body shop and ask them about it, it's used after body filler because it sands much smoother. You also use a higher grit sand paper with it but isn't necessary unless you want to paint.
Some resins have a kind of wax in them, which when used will rise to the top as it dries and makes it easier to sand. Kind of like slag in a weld. At least, this is the conclusion I draw from staying up til midnight looking for the cheapest resin that can be shipped to Michigan..
So what was cheapest //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
They're all about the same price shipped. Cheapest so far was the stuff Req uses, which is about $34 shipped. I'm trying to remember if the Bondo stuff from the local Autozone was $29 or $39 / gallon.
SSplaytoy
SSplaytoy
Hialeah
NDMstang65
