Fi q
with the bp , they rate it at around 300-500wrms more than what the stock Q is, iirc. you can check thier website, it has more info on that.
id still say turn your gains down a bit. probably to ~1500wrms and youll be fine.
with the bp , they rate it at around 300-500wrms more than what the stock Q is, iirc. you can check thier website, it has more info on that.id still say turn your gains down a bit. probably to ~1500wrms and youll be fine.
its 100 to 200watts;)
its 100 to 200watts;)it;s on the fi form. fyi
I've used a single Q on an SAZ1500d @1ohm, stock.
With BP power, you should be fine. Just set your gains correctly.
nG
x2 very good sub, set ur gains and you will be fine... I had a single 12 sx beat to death off my memphis @1100x1 AND my pals rf 2k .. and that off my DMM should have been getting right around 2600 on burps and 1700 daily w imp and box rise.. ur fine , just dont be stupid w the gains
conn.am
conn.am
Celina, OH
hzsogood
