Fi Neo prototype anyone?
After reading the first post. Ill still be willing to bet the Warden is the best priced Neo Availble when it comes to performance/cost ratio.
You just like to ride the wardens nuts //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Not really though. Think about. Neo subs are higher powered. So losing 10 pounds per subs means 10 more pounds added to the amp to push it and the 100 lb batts needed to power that amp. So to lose 10 pounds going to one of the better neo subs available such as the warden, 95z or one of these means 100+ lbs atleast extra added to make it right.
Good point. +1
At this point money should no longer be an issue for Fi, whether it be paying to develop proprietary baskets or whatever. And I'm not saying there's something "wrong" with a 12 spoke basket, but a subwoofer company that's continuously growing should eventually put some money into making their subs physically different than the dozens of other companies out there.
And this applies to several other companies as well. I'm not picking on Fi alone...
Would you want to pay the extra money for it if there's no need for it? That's be like saying that they should use a high roll surround for more excursion, even though the spiders will tear before the half roll surround breaks(hypothetically).
Can't argue with this man when it comes to DC //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Glad i'm not caught up on a brand....good feeling
lies. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Just because a sub uses a neo motor doesn't mean its going to require 2500 watts just to get it moving like a Warden or DD Z.
neo subs are lighter and generally have more BL. This makes them more effecient and actually require less power than a undermotored couterpart. However, most people use RMS as a requirement and not as what the speaker can handle before you begin to break it down over longterm use.
warden - garbage
FI neo - maxi pad styling
dc - not even close to designed fully
dd- more than most used cars
when is some one going to get a good looking/good performing neo sub that people can afford put together
twistedchild420
twistedchild420
East,TX
JL Audio
