FI Btl n2
Depends on the coil honestly. Most highend 3"coils like 2500-3000 daily.. that's about there limit. Unless you have a huge 8 layer 70+mm coil.
I'm not sure on the full specs on the coil but I know they are fully loaded with the flatwind coil and all that good stuff. Theyd only be down to .5 for burps and up to 2 for daily
I would do half ohm daily.
Those woofers are designed for burps but I'd imagine they could take a clean 3kw.. you can strap them at 2ohm for daily it will be fine..
I thought the n3s were more built for spl and n2s were more ground pounded oriented? I guess I'll give em a whirl and see how they take it.
I could be wrong money. It's been a few years and they might be more of a street beat. You have any tech info?
This is what I could find
N218
DUAL 1 | DUAL 2
Fs: 34.0 Hz | 33.6 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 8.18 | 8.28
Qes: .32 | .32
Qts: .31 | .31
Mms: 336g | 344g
Sd: 1210cm^2 | 1210cm^2
Vas: 133.8 l | 133.8 l
Spl: 94.0dB 1W/1m | 93.8dB 1W/1m
Bl: 17.8 N/A | 25.1 N/A
Xmax: 28mm * | 28mm *
Rms: 2000W * | 2000W *
Sealed box: N/A cuft | N/A cuft
Ported box: 4.5-8.0cuft | 4.5-8.0cuft
Sub OD: 18.500” | 18.500”
Cut ID: 16.750” | 16.750”
Mounting depth: 11.125” | 11.125”
Displacement: 0.18cuft | 0.18cuft
---------- Post added at 02:24 AM ---------- Previous post was at 02:24 AM ----------
What kind of power is he running?
I'd say they are abit more of an spl driver but with some tuning should pound daily.. I would go much more than about 3500 and even then make sure it's clean.. very low mms decent motor strength. I'd say try a flat wall with them in 5.5 to 6 tuned to 34-36.. they will do nicely 6th oder but unless you go really big and tune really low it's gonna play from 34-70 nicely. If yo uh want abit more low end do a flat wall with a shitton of Port area..
I was planning to do a flat wall drivers side port or a 6th but I wasn't sure about the sixth. I'm gonna talk to a local who builds boxes and what not about how we could do it
I may end up getting something else that's does a little bit better on the low end but we can see what we can do with them
Zarate76
Zarate76
Lincoln, NE
TheFiverMan
