Sold Few goodies and rare EQ F/S
Belunt
Resurrected
I'm picking up some rims soon so I'm unloading most of my audio gear since I'm redoing my install for next season. Pictures of everything will be up tomorrow, I might toss up some other items if I track anything else down
Used VCR setup for 12V. Model # AV-SVCPII (I tried tracking down some info on this and came up with nothing). It has a wired IR remote sensor for the remote control, got an Audio(R,L)/Video in & out RCA connections, also has ant. in & out (like the wall plug for your cable TV). Used but in great condition (working/cosmetic) only markings are on the side where I mounted some L brackets. I'm thinking $65 shipped, really couldn't find much on this to get a ballpark price. Pic HERE
Orion Concept 97 2, 30 Band Digital EQ (limited quanities made): Make offers (yeah I know the rules so say $39,000 or best offer //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif / I really don't know what to ask for it so make offers, I've seen them go for around $400 in good condition but I'm open to offers) It's used but in mint condition brushed aluminum, 1/3 octave, 30 band equalizer, features internal D/A and A/D 24 bit processing, balanced or standard RCA inputs, and digital inputs via Toslink or RCA coax with multiple presets. If anyone knows anything about these units they'll know I only listed a fraction of its features this was a solid EQ and very rare.
More to come
I'll get pictures up as soon as I can I left my camera at some girls place and I'm going to try and make it over there tomorrow. And yeah it's what you think //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
The EQ has 1 (set in and out) digital/analog, and 30 bands of equalization set to the exact frequencies on 1/3 Real Time Analyzers. Left and right channles can be adjusted individually:
Analog Input/Output:
-Input: The concept 97 2 uses an 18 bit balanced delta sigma analog-to-digital converter with 128 times oversampling. It accepts both RCA and Balanced (Mini XLR) inputs. Left and right input sensitivity adjustments are fully variable and independent
-Output: The analog output section is a wide dynamic range 18 bit continuous bitstream calibration digital-to-analog converter with 128 times oversampling. It has low total harmonic distortion with "zero crossover" distortion and incorporates digital de-emphasis. The output voltage (on either RCA or Balanced Mini XLR outputs) is 9 Volts RMS for the RCA outputs and 18 Volts RMS (9 Volts RMS output per phase) for a balanced system.
Digital Input/Output:
-Input: Professional grade SPDIF reciever, same receiver used in high-end home audio. Supports both 44.1 kHz and 48 kHz sampling frequencies and both TOSLINK and COAX digital inputs
-Output: Output frequency is 44.1 kHz, supports both TOSLINK and COAX digital formats. C-Lock Anti-Jitter clock recovery virtually eliminates jitter from a digital signal
A few other features of many are: 4 preset working zones, computer interface, isolated power supply for optimal noise insolation, 9 Volt RMS output (per phase), frequency centers, boost levels and "Q" values are exact. No variance like analog circuts, channels can be adjusted individually or linked together, LED display, internal fuse and much much more. I could go on about this EQ, hate to even let this go since it's limited edition and these are extremely hard to come by but I'm picking up some 22"s tomorrow and I'm redoing my entire setup.
And BassAddictJ I'd say this EQ is better than 83% of hot ***
Sorry for the delay, and I'll have pictures of Type R up later tonight. It's flawless, if anyone needs I can get more shots different angles.
Oh and here are new rims (22" 240 Spokes):
sickk rims //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif bumpp for a good seller //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
This is just a standalone unit no remote interface, there is talk in the manual about something like this to be released & computer interface it's hard to find much of anything on these though since they're hard to come by. So what you need the excercise //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif!
Belunt
Resurrected
Belunt
Joliet, IL
Belunt
