Sold Feeler - Rainbow Germaniums 465.25 and MB Quartz RAA2400
Starky
Alright heres the deal...I want to sell them but wont be able to get the boxes for them until I come home from School (start of may)
The Rainbow Germaniums 465.25...One of the 4 speakers has a little cut in it, about a quarter inch big, and a little dent to.(Have no idea how it happened since it was the one that was in the Door) I can sell Just 2 (or 3 if you wanted) speakers, making it a Rainbow Germaniums 265.25...The speaker with the cut works fine, and can probably be fixed...I actually didn't even notice there was anything wrong with it till I saw it, sounded fine...2 of the 4 speakers (one of which has the cut) have rusted screw downs on them (where you screw down the wire to the speaker)
The MB Quartz RAA2400 works great and looks great, does 2x200 (4ohm) and 2x400 (2 ohm) and 800 watts RMS x 1 in bridged mode (4-ohm stable)... has lots of cool features on it including a clipping light, a light that flashes when there is clipping...Oh and its miss the screw that holds down the plate that covers the control panel
Im not sure what I should sell these for Im thinking:
2 Speaker set - 300
3 Speaker Set - 350
4 Speakers - 375
(+shipping)
and the amp for 200+shipping
Speakers obviously come with Crossovers and Tweeters both of which work and look great
Speaker with Cut
One of the speakers with rust
The other Speaker with rust
AMP
Pretty positive I have the other Grills for the other speakers too
If someone would like to only buy the tweeters and crossovers from this set, I'd like to pick up a single set of just the mids to run in an active setup.
Let's make it happen! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Bump for you, man.
Bump for you, man.
Tat's cal25 silk or cal26 sile?
I dont think it does 1 ohm
400 watts RMS x 2 at 2 ohms
200 watts RMS x 2 at 4 ohms
variable front and rear high- and low-pass filters (50-5000 Hz at 12dB/octave)
CEA-2006 compliant
multiplier x10 switch converts filters to variable from 500 to 5,000 Hz
LED clipping indicators
preamp-level inputs and outputs
front end defeat bypasses gain and crossover controls
fuse rating: 30A x 3
4-gauge power and ground leads
11-7/16"W x 2-3/8"H x 17"D
Signal-to-Noise (S/N 1 Watt @ 4-Ohms) - >95 dBA (1 Watt @ 4-Ohms)
Frequency Response - 10Hz - 40kHz +/- 0.5dB
Bridgeable - Yes
Input Signal - 150mV - 8V RMS
Tone Controls - No
Signal Input - RCA
L & R independant gain control
Signal Output - RCA Pass-Thru
Crossover - 50Hz - 500Hz / 500Hz - 5kHz
12dB/octave
HP/LP/AP
Subsonic Filter - No
Phase Control - No
Indicators - Output Clipping (L & R)
Protection
Remote Controls - No
Dimensions - 28 cm x 40 cm x 5,8 cm
11.00" x 15.75" x 2.25"
Dissipation Technology - Extruded Aluminum Heatsinks
Feature Notes - Top mount controls, defeatable 'front end'
Starky
Starky
michigan
krisfnbz
