Sold Feeler: Eclipse CD8454
CJandMJsMatrix
i'm thinking of selling this deck in favor of the new 8555 that came out. i saw it on display and fell in love with it. i also like the added features, but certainly not the raised price! so i have to let this deck go before i can pursue the new one.
the deck will come with the credit card remote instead of the NOB one, a brand new owner's manual (as mine was torn up), and the wiring harness. the deck is only a couple of months old and is in excellent condition.
please post your offers up. thanks!
more info:
* The flagship unit in the new CD Receivers, the CD8454 sets a new standard in audio-dedicated music reproduction for the mobile environment. Whether the program source is CD, CD-R/CD-RW, MP3, radio broadcasts or even WMA files on a Memory Stick, sound quality is always exceptional. Music takes on the effortless quality that is the hallmark of the best audio components.* High Preamp Output Voltage The CD8454 circuits deliver a very high preamp output of 8 volts to help lower system noise and increase system dynamics since the power amplification stage can be driven optimally. The output signal’s low impedance of 55 ohms is also electrically ideal for audio signal transfer.
* Full-dot Vacuum Fluorescent (VF) Display This display makes best use of the space available with alphanumeric characters that retain high contrast in all light conditions. Brightness levels can be set to suit user preferences for day and night driving conditions and illumination can be switched from green to red. A graphic assist function helps confirm parameter changes.
Specifications: NOB Remote Control CD Changer Control CD-R/RW WMA MP3 Digital Servo System (DSS) TUNER STARTUNER® V Station Name Input AUDIO Output voltage and impedance 8V 55 Ohm MOSFET Amplification All digital circuitry 24-bit DAC DSP with Time Alignment, Parametric EQ, Crossover Electronic Crossover Control Non Fader Pre-out Dual Pre-out Digital Input Digital Output (for E-com) AUX In MEMORY STICK ATRAC3 Decode/Encode E-iSERV Connection Memory Stick ESN GENERAL ECLIPSE Security Network Display VF (Full dot) Full Face Tilt Bright & Dimmer Control ECLIPSE COMMANDER ADVANCE ready E-LAN data link system Current Drain 3A Dimensions (W ×H × D) 7" × 2" × 6-1/8" (178 × 50 × 155mm) FM TUNER Frequency Range 87.75 ~ 107.9 MHz (200kHz step) Usable Sensitivity 13dBf 50dB Quieting Sensitivity 14dBf Frequency Response 30 ~ 15,000Hz, ±3dB Stereo Separation 38dB (1kHz) AM TUNER Frequency Range 530 ~ 1,710kHz (10kHz step) Usable Sensitivity 20µV CD SECTION Frequency Response 20 Hz ~ 20,000Hz, ±3dB Wow & Flutter Below measurable limits Stereo Separation 85dB S/N Ratio (A-weighted) 100dB Dynamic Range 98dB Total Harmonic Distortion 0.01% AUDIO AMPLIFIER Power Output 13W x 4 (20 ~ 20,000Hz, 0.8%THD, 4Ohm) - MAX 50W x 4 Lineout Output Level/Impedance 8V(0dB)/55 Ohm Tone Control Bass +12dB at 80Hz Treble +12dB at 10kHz Loudness +10dB at 100Hz/+6.5dB at 10kHz MEMORY STICK PLAYER SECTION Frequency Response 20Hz ~ 20,000Hz, ±3dB S/N Ratio (A-weighted) 100dB Total Harmonic Distortion 0.01%
If you got a 400 offer I'd sell it to him if I was you. I sold the exact same deck about 2 months ago for the same price, doubt it will sell for much more. //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
Hey, you did PM me? I don't believe I ever got it. LOL.
Well, I recently got a NIB Alpine CDA-9853 so, unless you would take a trade plus cash, I will have to pass....
CJandMJsMatrix
CJandMJsMatrix
riverside/san diego, ca
CJandMJsMatrix
vegang
vegang
