fans push-push/pull-pull or push-pull
yea if you do one push thru the amp one way and do the other pushing in thru the other, it will eventualy allow a massive amount of dust to build up which will cause more heat than without the fans //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
Is it going to be sealed? If any air could be pulled in anywhere besides where the fans are, set them both as exhaust fans. This helps avoid hot spots because of a more uniform flow.
Unless of course, a fan will be blowing directly towards where you need it most.
Just run a duct from your A/C vents and never use your heat.
j/k, intake and exhaust fan //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
2 exhaust fans would be your 2nd option
2 intake fans is just *******
as for dust, every so often take duster and clean the **** thing off to keepit pretty //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Symon_say
You can't get me
Symon_say
Dominican Republic
BassAddictJ
