False floor?
false   [fawls] Show IPA
adjective, fals·er, fals·est, adverb
–adjective
1.not true or correct; erroneous: a false statement.
2.uttering or declaring what is untrue: a false witness.
3.not faithful or loyal; treacherous: a false friend.
You can build a new floor, but calling it a "false floor" is ignorant
false floor= not the correct floor, as the one below it is the CORRECT floor. hence being called a FALSE FLOOR once again.....
Floor
False Floor
OP had six days to digest this. Hopefully he has actually read the definition that he posted and realized that if its not the original floor that was designed by the manufacturer it is and will always be called false. From his own definition False = Untrue. Yes it is a real floor but its not the true floor for the car hense it is untrue or false.
exactly. not the original. i agree and will continue to use the term (not that this thread would have changed my mind)
You should flip the amp on the right so it faces the other.
i disagree. this allows for logical signal and power distribution. flip them and power and ground routing becomes much more complicated.
i think the time should be spent with some of these:
and some time with loom and routing for a safer install and nicer appearance.
no one sees under the beauty boards anyway so meh
theMessenjah44
theMessenjah44
Central IL
keep_hope_alive
