J Jake Junior Member 5 0 Iowa Aug 22, 2002 #1 Is it possible to use an amp to power just some 6x9s in the trunk with just a factory radio in the dash? i mean i wouldnt think that factory radio would have a pre amp output so how does that work? what would i have to do? Click to read more...
MikeofTulsa Moderator The one and Only! 26,789 6 Tulsa, OK Aug 22, 2002 #2 you'll need a line output converter which will splice into the existing speaker wires and convert the signal to a rca output...good luck
Corsica 5,000+ posts CarAudio.com Veteran 15,804 0 Ft Huachuca, AZ Aug 22, 2002 #3 Also u more than likely would need to oput a switch on ur power wire to turn the amp on and off cause otherwise its on 24/7 J
