The 4KW is the flagship of the Competition Series, consisting of two 9.0XD PC boards mounted in a single chassis. This World Champion in dB Competition owns multiple World Records since it's debuted. The 4KW the is the baddest of the bad, it will pound out over 1,000 watts from each of the four channels into 2 ohms or 1 ohm. Bridged to dual mono, it will produce roughly 5,000 watts, and do it in the smallest package in available.
- SymbiLink™ Balanced Line Technology provides up to 16 volts of balanced input for the cleanest, quietest signal possible
-Dual 1,800 watt power supplies per PC board for surges well in excess of rated output power for SPL use
- Three independent output filtering stages allow full
range use as well as bass use in SQ systems
- Optical isolation at each stage
- ZAPCO DCS microprocessor control for all amplifier
functions
- Ultra high speed switching frequency for reduced
"footprint"
-Adjustable input gain up to 30.5 dB
-Adjustable Pre-Clip circuitry enabling the user to set the maximum input which in turn determines the desired output. power. Match RMS speaker power handling for best performance and reliability
-Adjustable turn on delay from 1-4 seconds
-Two XD-VFD in-dash displays, with wired remote, allows monitoring and control of all functions from drivers position display shows, volume, input voltage, amplifier rail voltage, temperature and output power
- Variable, selectable 24dB or 48dB low pass
crossover
-Pass through output
-Four layer PC board with heavy 3 oz copper
-Surface Mount Technology w/1% resistors, precision capacitors, and massive ground planes
-Switch for use as stereo , single L ch. or R ch. bridge
-L+R sum mono for use as a bass amp-
-Dual cooling fans allow any mounting position
-Three year warranty (If Authorized Dealer Installed)
- Quality ZAPCO construction
** Designed and Manufactured in the USA **
Suggested Retail $ 8748.00
