i have for sale or trade a sundown saz 1500 i will let go for 325 and the specs straight from the sundown site are:
SPECIFICATIONS:
Double Sided Through Hole Epoxy PCB
Efficiency : 86% @ 4 ohm, at 100Hz
24dB/Oct Variable Crossover
Multi-Way Protection Circuitry
(Thermal/Over Current/Speaker Short/Speaker DC Protection)
Variable Subsonic Filter
Variable Bass Boost
Variable Low Pass Filter
Variable Phase Shift
Zero(0) Gauge Power Supply Connectors
Tested Voltage & THD : 14.4V & Less than 1% THD
Operating Voltage : DC 10V~18V
Digital Class-D Linkable Mono Block Amplifier
1 Ohm Stability
RCA Line Input and Master Output
24dB Octave Crossover Slope
Wired Remote Controller
PRODUCT MANUAL
MSRP $799 USD
Rated power output
----RMS power, 2 ohm linkable/dual mono
3000W x 1CH
----RMS power, 1 ohm mono
1500W x 1CH
----RMS power, 2 ohm mono 800W x 1CH
----RMS power, 4 ohm mono
400W x 1CH
Signal to Noise Ratio >90dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 40A x 4
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 252(W) x 58(H) x 434(L)mm
and i have a fusion fjl-1611d i will let go for 250 and specs from amp guts are:
1 x 600W @ 4 Ohms (12.6V - 1% THD+N)
1 x 900W @ 2 Ohms (12.6V - 1% THD+N)
1 x 1250W @ 1 Ohm (12.6V - 1% THD+N)
1 x 840W @ 4 Ohms (14.4V - 1% THD+N)
1 x 1250W @ 2 Ohms (14.4V - 1% THD+N)
1 x 1600W @ 1 Ohm (14.4V - 1% THD+N)
Fuse: 4 x 30A
both amps are 10/10 working condition the sundown is 9/10 cometically it has scratches on the bottom but when mounted u dont see them and the fusion has a few scrapes and is missing 1 screw for the speaker output. if u are truly interested pm me or email at tokyoskaterblah@aol.com for pix or can send a pic message through cell, i will consider any trade, within reason. the sundown was pushing a 18" fi and the fusion i had linked to another fusion 1611d on a solo x. i am looking for a few decent 12s dont have to be anything major.
oh and btw i have a mtx thunder240 white amp and a alpine mrd-m300 amp for sale also taking offers on anything message me
SPECIFICATIONS:
Variable Bass Boost
1 Ohm Stability
PRODUCT MANUAL
MSRP $799 USD
Rated power output
3000W x 1CH
1500W x 1CH
400W x 1CH
T.H.D @ 4 ohm
Fuse rating 40A x 4
Fuse: 4 x 30A
