Sold F/S or Trade RE SX 18" and Cadence TXA-1000D
MyKuL
18 Inches of Pleasure
I'm getting a new car and need something a bit smaller.
Specs for SX 18 are:
Electrical Q Value -Qes: 0.53
Mechanical Q Value -Qms: 6.1
Total Speaker Q Value -Qts: 0.48
Free Air Resonance -Fs: 33.2 Hz
Equivalent Compliance -Vas: 159 liters
One-Way, Linear Excursion -Xmax: 22 mm
Efficiency -SPL 1W/1m: 92.7 dB SPL
Effective Piston Area -Sd: 1210 cm^2
DC Resistance -Re: 1.9 ohm
Nominal Impedance -Znom: Dual 2/4 ohm
Thermal Power Handling -Pe: 1000 W
Force Factor -Bl: 21
The 18 was used for a total of about 4 hours but I managed to build a leaky box and break the spider former. It has been reconed by Scott of Fi Audio and is basically brand spankin new. There are no scratches or smudges on the sub. It has not been used since it's recone. This sub is in absolutely PERFECT condition.
$275 shipped and interested in trades.
Specs for Cadence TXA-1000D are:
Amp specs:
4 Ohm RMS Power: 1 x 350 Watts @ 13.8 Volts
2 Ohm RMS Power: 1 x 650 Watts @ 13.8 Volts
1 Ohm RMS Power: 1 x 1000 Watts @ 13.8 Volts
2 Amps Bridged 2 Ohm RMS Power: 2000 Watts
Frequency Response: 20Hz - 500Hz
Damping Factor: >500 @ 100Hz
S/N Ratio: >100 db
Minimum THD:
Dimensions: 25" x 9.2" x 2.12"
High Speed Mosfet Power Supply
Studio Grade Bipolar Output Stage Transistors
Fully Adjustable Low Pass Filter 50-150Hz
Fully Adjustable Bass EQ 0-18dB @ 40Hz
Fully adjustable Subsonic Filter 11-47Hz
Adjustable Input Gain 170mV-8V
Phase Shift Control 0-180
Ultra Reflective Chrome Top Cover
Subwoofer Controler Included 18dB @ 40Hz
Bridge Link-Multi Amplifier Master/Slave Control
Power and Protection LED Indicators
Full IC Controlled Protection Circuitry
Mute and Soft Delay Circuitry
Lucite Encapsulated Terminals
This amp has never been used and has only been taken out of the box for pictures and inspection. It is in perfect condition with no scratches or smudges. It comes with an external fuse with fuse holder and a bass knob.
$160 shipped with 2 year warranty, also interested in trades.
More pics are available upon request.
MyKuL
MyKuL
Georgia
MyKuL
