Sold F/S or Trade RE SX 18" and Cadence TXA-1000D
MyKuL
18 Inches of Pleasure
I'm getting a new car and need something a bit smaller.
Specs for SX 18 are:
Electrical Q Value -Qes: 0.53
Mechanical Q Value -Qms: 6.1
Total Speaker Q Value -Qts: 0.48
Free Air Resonance -Fs: 33.2 Hz
Equivalent Compliance -Vas: 159 liters
One-Way, Linear Excursion -Xmax: 22 mm
Efficiency -SPL 1W/1m: 92.7 dB SPL
Effective Piston Area -Sd: 1210 cm^2
DC Resistance -Re: 1.9 ohm
Nominal Impedance -Znom: Dual 2/4 ohm
Thermal Power Handling -Pe: 1000 W
Force Factor -Bl: 21
The 18 was used for a total of about 4 hours but I managed to build a leaky box and break the spider former. It has been reconed by Scott of Fi Audio and is basically brand spankin new. There are no scratches or smudges on the sub. It has not been used since it's recone. This sub is in absolutely PERFECT condition.
$275 shipped and interested in trades.
Specs for Cadence TXA-1000D are:
Amp specs:
4 Ohm RMS Power: 1 x 350 Watts @ 13.8 Volts
2 Ohm RMS Power: 1 x 650 Watts @ 13.8 Volts
1 Ohm RMS Power: 1 x 1000 Watts @ 13.8 Volts
2 Amps Bridged 2 Ohm RMS Power: 2000 Watts
Frequency Response: 20Hz - 500Hz
Damping Factor: >500 @ 100Hz
S/N Ratio: >100 db
Minimum THD:
Dimensions: 25" x 9.2" x 2.12"
High Speed Mosfet Power Supply
Studio Grade Bipolar Output Stage Transistors
Fully Adjustable Low Pass Filter 50-150Hz
Fully Adjustable Bass EQ 0-18dB @ 40Hz
Fully adjustable Subsonic Filter 11-47Hz
Adjustable Input Gain 170mV-8V
Phase Shift Control 0-180
Ultra Reflective Chrome Top Cover
Subwoofer Controler Included 18dB @ 40Hz
Bridge Link-Multi Amplifier Master/Slave Control
Power and Protection LED Indicators
Full IC Controlled Protection Circuitry
Mute and Soft Delay Circuitry
Lucite Encapsulated Terminals
This amp has never been used and has only been taken out of the box for pictures and inspection. It is in perfect condition with no scratches or smudges. It comes with an external fuse with fuse holder and a bass knob.
$160 shipped with 2 year warranty, also interested in trades.
More pics are available upon request.
the sx is dual4 ? I probably read over it.
Sorry, I forgot to mention, it's a dual 2. Good looking out for me //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If anyone is interested in trading, I would like something that is possibly a 12" sq sub or something similar, and an amplifier that does around 500-800 watts. I'm pretty flexible when it comes to trades, but I would like to keep it on the sq side of things.
Thanks
YGPM and I think those are the RE XXX specs. And if fi reconed it, is it a BTL recone with a RE dustcap?
Thanks for catching that. Here is a message from Scott regarding my questions about the parts used.
Sales Fi Car Audio to me
show details Jan 20 Reply
The TS params would be the same as the original RE SX. We use the same
parts as the SX line does for recones and I would simply follow the original
recommendations for the sub.
Please let me know if I can help with anything else.
Thanks,
Scott
Fi Car Audio
- Show quoted text -
----- Original Message -----
To:
Sent: Friday, January 18, 2008 9:33 AM
Subject: T/S Parameters
>I recently had an RE SX18 sent to Fi Car Audio for a recone and the Fi
> soft parts were used, if I remember correctly. I am planning to start
> on my install shortly later on and was wondering if it is possible for
> me to get some T/S parameters on the subwoofer.
> Thanks,
> -Mike
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.5.516 / Virus Database: 269.19.6/1230 - Release Date: 1/17/2008
> 4:59 PM
interested in that sub..as far as trades ive got a hdc3 15" only 1 day of playtime..i like that 54mm xmax...
In my past SPL life, I would have said yes... very tempting, sir... but I'm leaning towards SQ //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
havent u heard?? the hdc3 is now the SQ frontrunner!
you never got back to me on my 10s I posted a link to above //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif their sq subwoofers
I'll have to get back to you on those 10's. They look pretty good but I will let you know.
MyKuL
MyKuL
Georgia
MyKuL
