Sold F/s new saz-4500d
loudwhat?
The Sundown Audio King
I have a new Sundown Audio SAZ-4500D
*NO TRADES PLEASE*
Specs:
* Double Sided Through Hole Epoxy PCB
* Efficiency : 86% @ 4 ohm, at 100Hz
* 24dB/Oct Variable Crossover
* Multi-Way Protection Circuitry
* (Thermal/Over Current/Speaker Short/Speaker DC Protection)
* Variable Subsonic Filter
* Variable Bass Boost
* Variable Low Pass Filter
* Variable Phase Shift
* Dual Zero(0) Gauge Power Supply Connectors
* Tested Voltage & THD : 12.8V & Less than 1% THD
* Operating Voltage : DC 10V~18V (Absolute Maximum 18.5 volts)
* Digital Class-D Linkable Mono Block Amplifier
* 1 Ohm Stability
* Wired Remote Controller
Rated power output
----RMS power, 2 ohm linkable/dual mono
9000W x 1CH
----RMS power, 1 ohm mono
4500W x 1CH
----RMS power, 2 ohm mono 2000W x 1CH
----RMS power, 4 ohm mono
900W x 1CH
Signal to Noise Ratio >90dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~50Hz
Bass boost @ 45Hz 0~9dB
Phase shift control 0~180 degree
Frequency response 10Hz~250Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 500A (external type fuse)
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 12.2"(W) x 2.68"(H) x 25.59"(L)
MSRP $2149 USD
i am asking 1250 OBO shipped in the continental US
*NO TRADES PLEASE*
*NO TRADES PLEASE*
I will keep in touch if this doesnt sell. I should close the sell on the first of my 3 amps today so I may be able to get the money together to drop on it.
loudwhat?
loudwhat?
statesville, nc
loudwhat?
