Sold F/S MTX Thunder 500d 500watts @2 ohm 12 volts!
ampjunkielikeme
100.00 shipped to the cont usa no trades...
i wanted to list this one here before i list it on ebay...anyways
this is a mtx thunder 500d class d mono amp....it works 100% and will pound the crap out of some subs...i checked it out. benched it for a couple hours with no problems at all...
amp should put out almost 600watts @2ohms rms......don't be fooled by its small size...it puts out some power
specs:
RMS Power at 12.5V:
1 x 250W @ 4 ohms (
1 x 500W @ 2 ohms (
Damping Factor: >200
Freq. Response: 20Hz ∼ 200Hz
Fuse: 3 x 25A
Dimensions: 9" x 9" x 2"
3 x 25A Dimensions: 9" x 9" x 2"
thanks for the bump...
i have its big brother...a thunder 1000d . its birth sheet says it puts out 1250 watts @2ohm 12 volts .so the amp should put out a easy 600 watts rms @2 ohms....
thanks for the bump...i have its big brother...a thunder 1000d . its birth sheet says it puts out 1250 watts @2ohm 12 volts .so the amp should put out a easy 600 watts rms @2 ohms....
No problem, the last MTX I had like that was the small one, the Thunder 102. Rated at 25w RMS per channel, it was putting out more like 50w to 60w, had no issues running my front stage at the time. Really nice amps.
ampjunkielikeme
ampjunkielikeme
nash, tn
ampjunkielikeme
