Sold f/s mtx thunder 304 4 channel
ampjunkielikeme
100.00 plus shipping .....this is a clean mtx thunder 304..its in 100% working order...in near mint condition....this amp sounds great and is ready to make some mids and tweets scream for mercy....
pics; missing a fuse but i will put one back in it... works 100%
RMS Power measured at 12.5 Volts DC:
37.5 Watts x 4 into a 4 Ohm load with less than 0.1% Thd+N
75 Watts x 4 into a 2 Ohm load with less than 0.3% Thd+N
150 Watts x 2 bridged into a 4 Ohm load with less than 0.3% Thd+N
(IHF-202 Standard) measured at 14.4 Volts DC
90 Watts x 4 into a 4 Ohm load
165 Watts x 4 into a 2 Ohm load
325 Watts x 2 bridged into a 4 Ohm load
Signal to Noise Ratio:
110dB A-Weighted
Damping Factor:
>200
Frequency Response:
20Hz-20kHz ± 0.25dB
Maximum Input:
8Vrms
Thunder EQ:
Variable Bass Boost (0-18dB) centered at 40Hz
Crossover:
Variable 40Hz to 200Hz, 12dB/octave high pass,
24dB/octave low pass with mono output
pm replied...........
thanks revrider1......
yea it is a solid amp ,and puts out some great sound , even has a built in hp/lp crossover ...... this amp has not been used at all..... i bought it from a guy that bought it new and he only used it a month and sold it to me....ive had it setting in my room just collecting dust....this amp needs to be put to some use!...
ampjunkielikeme
ampjunkielikeme
nash, tn
ampjunkielikeme
