Sold f/s MINT DLS A3 TWIN MONOBLOCK AMPLIFIER / AUTHENTIC & PERFECT CONDITION! ORG BOX
desertheat
Up for grabs is one of the amps from my show car. Amp is MINT / As new with original box.
IMO, the BEST amp ever built to power a front stage. Simply an amazing performer & build quality is second to none.
Amp came directly from Pinny, the DLS rep so it is guaranteed authentic and not a copy. I have gut shots for proof.
$370 shipped
Also I have two of these, will post the 2nd after this sells.
The amps ARE out of the car ready to ship / boxed up. I can take pics of either to verify they are flawless & as described.
FIRST COME FIRST SERVE AT THIS PRICE.
Specs as follows...
RMS output per channel at 13,8 volts, 20 Hz - 20 kHz ,
Mode : AB
Number of channels : 2
Output power in 4 ohm : 2 x 150 watt
Output power in 2 ohm : 2 x 270 Watt
Output power in 1 ohm : 2 x 425 Watt
Output power in 4 ohm bridge mode : 550 Watt
Output power in 2 ohm bridge mode : 870 Watt
Output power in 1 ohm bridge mode : 1200 watt
S / N ratio, A-weighted : > 100 dB
Damping factor : > 200
Input impedance : > 10 kohm
Input sensitivity, variable : 0,2 - 7 V
Filter, highpass, variable : 20 - 200 Hz
Filter lowpass, variable : 50-125 Hz
Terminal for external cooling fan : Yes
Double DC-inputs : Yes
Phase shift button : Yes
Current draw, idle : 1,1 A
Current draw, maximum : 140 A
Dimensions W x D x H : 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Weight : 6,2 kg ( 13,67 lb)
Feel free to check out the review of the amp, the translated section is at the bottom
http://www.dls.se/files/565/2/A3_polish%20test.pdf
desertheat
desertheat
Tempe, Az
desertheat
