Sold f/s MINT DLS A3 TWIN MONOBLOCK AMPLIFIER / AUTHENTIC & PERFECT CONDITION! ORG BOX
desertheat
Up for grabs is one of the amps from my show car. Amp is MINT / As new with original box.
IMO, the BEST amp ever built to power a front stage. Simply an amazing performer & build quality is second to none.
Amp came directly from Pinny, the DLS rep so it is guaranteed authentic and not a copy. I have gut shots for proof.
$370 shipped
Also I have two of these, will post the 2nd after this sells.
The amps ARE out of the car ready to ship / boxed up. I can take pics of either to verify they are flawless & as described.
FIRST COME FIRST SERVE AT THIS PRICE.
Specs as follows...
RMS output per channel at 13,8 volts, 20 Hz - 20 kHz ,
Mode : AB
Number of channels : 2
Output power in 4 ohm : 2 x 150 watt
Output power in 2 ohm : 2 x 270 Watt
Output power in 1 ohm : 2 x 425 Watt
Output power in 4 ohm bridge mode : 550 Watt
Output power in 2 ohm bridge mode : 870 Watt
Output power in 1 ohm bridge mode : 1200 watt
S / N ratio, A-weighted : > 100 dB
Damping factor : > 200
Input impedance : > 10 kohm
Input sensitivity, variable : 0,2 - 7 V
Filter, highpass, variable : 20 - 200 Hz
Filter lowpass, variable : 50-125 Hz
Terminal for external cooling fan : Yes
Double DC-inputs : Yes
Phase shift button : Yes
Current draw, idle : 1,1 A
Current draw, maximum : 140 A
Dimensions W x D x H : 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Weight : 6,2 kg ( 13,67 lb)
Feel free to check out the review of the amp, the translated section is at the bottom
http://www.dls.se/files/565/2/A3_polish%20test.pdf
GOD I want this amp. Looks beautiful, and would match up with my Memphis ST3004 very nicely.
Sucks being broke. Any chance you'd trade it for an Orion XTR Pro 1000 and an Alpine 3672 active crossover unit.
**Crosses Fingers**
Ah STELLAR SQ sub. Very impressive to me. Heard the current owner... well wants somthing louder and less weight //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Were enough to flex my roof on the tc with ease and only 200rms each. 5x more bass than I ever needed haha.
Yup, I'm going to run them in a sealed downfiring box. Should sound very nice.
desertheat
desertheat
Tempe, Az
desertheat
