Sold F/S Memphis Mojo 16-MCD4KW BROKEN- 275.00 shipped
ampjunkielikeme
275.00 shipped to the cont usa......no trades..cash only
i rebuilt the power supply in this amp.... it now powers up fine, and produces good rail voltage....
the amp has sound at lower volumes, but if you turn the amp up. the sound will cut out... turn it down, you will get your sound back..(probably needs the output section rebuilt)
the board looks good.... nothing is burnt
i do not have the time, or money to invest in the amp any more, so it has to go....
should be a easy fix for the inclined individual.....
I feel for you man, I know what you mean. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif//content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif//content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
they run .5ohm if you have a shit ton of battery to back them up. they pop under 11v, but if you're responsible and know what you're doing you'll get an assload of power //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
someone buy this
memphis wants 300.00 to fix it. no matter what is wrong with it...
* 1000x1 @ 4 ohms
* 2000x1 @ 2 ohms
* 4000x1 @ 1 ohm
* CHARGING SYSTEM UPGRADES ARE MANDATORY WHEN USING THIS AMPLIFIER!
* 4000 Watts RMS @ 1 ohm
* Bridgeable In Pairs
* requires external bridging module (16-BRIDGE)
* Built-in Fully Variable Low-Pass Crossover
* Variable from 50-250Hz
* Built-in Fully Variable Sub-Sonic Filter
* Variable from 20-50Hz
* 1000x1 @ 4 ohms
* 2000x1 @ 2 ohms
* 4000x1 @ 1 ohm
Bump for a great amp. 575 is still a good price but im sure it can be repaired for less.
ampjunkielikeme
ampjunkielikeme
nash, tn
RetroAudioinc
