I just recieved this amp today in a trade, however I have no use for this amp, but it is pretty much brand new in it's origonal box. The cheapest I have found online for this amp is $149.99 + shipping, I'll let it go for $140 shipped. My friend bought this from audiosource (our local audioshop) for $299.99, less than 2 months ago, and it has seen very little playtime, and was sitting in his closet when I he offered me a trade. I will accept trades, Im looking for a small 2 channel amp no more than 100rms x 2 @ 4ohms, to power my components. Cosmetically I give this amp a 10/10, and as for its peformance, hands down would be 10/10.
Trades: Sundown Sax-100.2 & Others.
$115.00 Shipped OBO~
Specs are as follows:
Rated Power (mono):
120 W RMS x 1 @ 4 ohm (12.5V);
200 W RMS x 1 @ 2 ohm (12.5V)
THD at Rated Power:
S/N Ratio: >104 dB referred to rated power (A-weighted, 20 Hz ヨ 20 kHz noise bandwidth)
Frequency Response: 10 Hz ヨ 25 kHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm / 50 Hz,
>100 @ 2 ohm / 50 Hz
Slew Rate: ᄆ 22V/ᄉs
Input Range: 200mV ヨ 8V RMS
Dimensions: 9.8" x 9.25" x 2.36"
Features:
Absolute Symmetry Class AB Circuit (U.S. Patent #6,294,959)
Differential, Noise-Cancelling Input Topology:
RCA jack inputs (low-level) and multi-pin jack (high-level)
On-board Crossover: State-variable, 12dB/octave Butterworth with continuously variable cutoff frequency selection from 50 ヨ 200 Hz. Configurable as Low-Pass or High-Pass
Preamp Output: Pass-through type.
Speaker output connections: accept up to 8 AWG wire
+12V and Ground connections: accept up to 4 AWG wire
Rated Power (mono):
THD at Rated Power:
>100 @ 2 ohm / 50 Hz
Slew Rate: ᄆ 22V/ᄉs
Features:
