Sold F/S Hifonics XX OLYMPUS 1000watts RMS-250x4@1ohm- huge 4 channel amp.
ampjunkielikeme
250.00 shipped to the cont usa...No trades...
this is the amp you need to run those multiple sets of comps in your ride to the brink of destruction....//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
big daddy Hifonics xx olympus 4 channel amp.. it has all the button and knobs you could ever want..lol frequency multipliers,crossovers,bandpass..etc..it even has 2 built in fans to cool the beast .
you don't see many true 1000 watt 4 channel amps everyday. it could run a pair of subs if you wanted. (has a built in subsonic filter, and loww pass crossover). or your whole system.. mids tweets, and subs.. options are endless...
amp has been bench tested with all channels driven, and it works great...
the logo on the top of the amp glows red..i always thought they were blue..??... they could be blue if the buyer wants to pay me to change them..
cosmetically i would give the amp a 8 out of a 10.. it has a few scuffs and scratches..no end caps..i have the mounting feet for the amp.. they are not in the pics..
functionality, i give it a 10 out of a 10.. it works great.. this is a very powerful 4 channel amp..
specs:
* Super Class A/B Design
* Turn On Delay
* Frequency Response 2Hz - 70 K Hz (-3dB)
* Damping >280
* Signal to Noise Ratio >93 dB
* THD + Noise 0.03%
* Channel Separation > 70 dB
* Variable Input Level 0.2V - 9V (RCA/Unbalanced)
* Variable Input Level 0.4V - 18V (Mini DIN Balanced)
* 2 Hi Output Whisper Fans
* Full PMW Ultra-Fi Mosfet Power Supply
* LP-BP/Full/HP Crossovers
* Variable 12 dB/Octave High Pass Filter (10 Hz- 4 KHz)
* Variable 12 dB(24 dB Mono)/Octave Low Pass Filter (40 Hz - 400 Hz)
* Bass EQ 0-18 dB
* Variable Phase Shift (Off/On/Stereo) 0-180 Degrees
* Unbalanced and Balanced Inputs(Requires XX-BLD Line Driver)
* 125 watts RMS x 4 channels into 4 Ohms (stereo)
* 200 watts RMS x 4 channels into 2 Ohms (stereo)
* 250 watts RMS x 4 channels into 1 Ohm (stereo)
* 400 watts RMS x 2 channel into 4 Ohms (bridged)
500 watts RMS x 2 channel into 2 Ohms (bridged)
Dimensions 11.10 W X 2.75" H X 20.86" L (Endcaps + 5.32")
the amp is sold with no warranty expressed or implied... it has been tested, and it works as it should.....it will not arrive doa..
how much money do you have?
i can hold it until you pay it off....just as long as its not a long time..... LayAway!...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I might have to do this.. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I just can't seem to get ahead.. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
ampjunkielikeme
ampjunkielikeme
nash, tn
BassAddictJ
