this amp belongs to BassAddictJ . i am listing it for him, so if you have any questions pm him..
900.00 O.B.O. (or best offer) plus shipping
this is a hifonics xx-cyclops 4000 watt mono block amp.
the amp works perfect.
cosmetics- i would give it a 8 out of a 10. it has some scuffs and scratches..
functionality- 10 out of 10.. it has zero problems. works as it should..
the amp comes with a enclosure that cools the amp with 10 fans. it also has 12 blue led light to light up the board at night. all of it is hooked up to a separate relay so it doesn't pull to much current from your remote wire..
it covered in spray bedliner.plexiglass top covering the guts of the amp... looks kinda cool if you ask me...lol
you will never overheat the amp again!..
specs:
# 1500 watts RMS x 1 channel into 4 Ohms (bridged)
# 2900 watts RMS x 1 channel into 2 Ohms (bridged)
# 4000 watts RMS x 1 channel into 1 Ohms (bridged)
# Ultra D Class Design
# Turn On Delay
# Frequency Response 2Hz - 70 K Hz (-3dB)
# Damping >400
# Signal to Noise Ratio >98 dB
# THD + Noise 0.1%
# Variable Input Level 0.2V - 9V (RCA/Unbalanced)
# Variable Input Level 0.4V - 18V (Mini DIN Balanced)
# Full PMW Ultra-Fi Mosfet Power Supply
# Variable 24 dB Octave Low Pass Filter (35 Hz- 250 Hz)
# Variable Bass EQ 0-18 dB (30-60 Hz)
# Variable Subsonic Filter (10-50 Hz)
# Variable Phase Shift (Off/On/Stereo) 0-180 Degrees
# Unbalanced and Balanced Inputs(Requires XX-BLD Line Driver)
# Remote Bass Control Included
# Dual 2 Guage Power Terminals
# 10 G Speaker Terminals
# Suggested In-Line Fuse Rating 300 Amps
Dimensions 11.20 W X 2.60" H X 23.75" L
specs:
# Turn On Delay
# Damping >400
# THD + Noise 0.1%
