These were purchased for a temp install in my astro until i had funds to start my real build but summer keeps getting closer and closer that its not worth the time an effort to go thro w/ it. They are all basicly new, they were just tested for function and they all look and work flawless. Would work great of a 1500-2000rms amp @ 1 ohm. I also will include a free box design if anyone is intrested. Enough talk and onto the pics....
SD-1 10"
The Sundown Audio SD-1 10" subwoofer was made in the USA to some of the most exacting standards in the industry. The SD-1 is capable of producing great sounding bass in lower powered applications without breaking the bank. This woofer was designed with incredibly small enclosures and shallow mounting areas in mind.
FEATURES AND SPECIFICATIONS:
Non-conductive Kapton voice coil former for reduced eddy-currents and improved sound quality
Chamfered pole vent for increased cooling
Rigid polypropylene cone for long life in the harsh car environment
Rear mounting gasket for an air tight seal
Strong stamped steel basket
Extremely shallow mounting depth of only 5 inches
Single 8 ohm coil to easily match any Sundown Audio Amplifier; a pair works great with the SAX-100.2 and as many as eight can be ran from an SAZ-1500D with excellent results!
$110 US Dollars - MSRP
$137 Canadian Dollars - MSRP
T/S Parameters:
RMS: 200 watts
Peak: 350 watts
Z: 8 ohms
Re: 6.93 ohms
Fs: 25 Hz
Qms: 8.8
Qes: 0.36
Qts: 0.34
VAS: 67 L
BL: 17.5 NA
$300 Shipped for all 8
Will consider trades
Corey
SD-1 10"
T/S Parameters:
RMS: 200 watts
Peak: 350 watts
Z: 8 ohms
Re: 6.93 ohms
Fs: 25 Hz
Qms: 8.8
Qes: 0.36
Qts: 0.34
VAS: 67 L
BL: 17.5 NA
Corey
