Sold F/S: Eclipse xa-4000 amp 4/3/2 channel
pcoastsurf
Like new only installed for a month selling all audio Eclpise xa-4000 $255.00
shipped
Adaptable four channel amplifier that can be bridged to configure a more powerful two channel unit that provides 350W per channel. Subsonic filter and variable bass boost are provided as well as high and low pass filters.
ICEpower full-range Class D operation.
Attractive design for practicality and ease of use with all controls such as level, crossover, low frequency boost and high/low pass filter adjustments mounted on the top panel.
Output terminals conveniently located to allow multiple in-line unit installations.
Bright LED indicators also mounted on the top assist in setting system levels to prevent amplifier clipping.
Very high efficiency rate with low current draw.
ICEpower technology—full range Class D power
Highly efficient FET power supply
Variable 30-500 Hz 18 dB high-pass crossover
Variable 50-500 Hz 18 dB low-pass crossover
Variable 0-8 dB Bass Boost
Fully variable Subsonic Filter from 32-64 Hz
Illuminated Eclipse logo power indicator
Clipping indicator LED
Multi-Channel Amp SpecificationsAmplifier Type: Multi-Channel
RMS Power @ 4 Ohms: 125W x 4 @ 14.4V
@ 2 ohms 175 x
THD at 4-Ohm RMS Power: 0.05%
Bridged RMS Power @ 4 Ohms: 350W x 2 @ 14.4V
Speaker Level Inputs: no
Preamp Outputs: yesBuilt-In Crossovers: HP/LP
Bass Boost: 18 dB
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: >90 dB
Fuse Rating: 3 x 30 amps
pcoastsurf
pcoastsurf
SAN LUIS OBISPO, CA
LiquidClen
