Sold F/S Eclipse 3640 4 channel 240 watts rms
ampjunkielikeme
(sold)
old school Eclipse 3640 4 channel amp that works 100%. i tested it for a few hours prior to listing. it has never been repaired.
it has some light scuffing on the heatsink. it looks very good for its age. nothing that hurts the performance. it's a audiophile grade amplifier. one of the best sound quality amps made by eclipse. they were known to be very underrated.
the best part about it is was made in the usa.(says it right on the bottom plate). they just don't make them like this anymore..it would be perfect for running a set of components or a small sub and 2 6x9 speakers. etc.. you wont be disappointed.
105W rms x 4 Channel Max. Power Output at 2ohm Stereo
60W rms x 4 Channel 0.1% THD 2ohm each channel
40W rms x 4 Channel 0.1% THD 4ohm each channel
120W rms x 2 Channel 0.01%THD 4ohm each channel
ChannelFlex Crossover
Adjustable High-Pass Frequency (50200Hz, L/R Independant)
Low-Pass Frequency (120Hz)
Adjustable Bass-Boost Level (45Hz, 09dB, F/R Separate)
High-Current, High-Speed Output Devices
High-Efficiency, High-Energy MOS FET Power Supply
Audiophile Grade Component Selection
Intelligent 7-Way Discrete Protection Circuitry
Noise Reduction with Low Distortion & Ultra-Low Negative Feedback
High-Level Input - Add on Capability
Epoxy Composite PCB
2ohm Stable Design
I will ship the amp the same day you pay for it..i also pack my items very well. so no worries about it getting broken.. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ampjunkielikeme
ampjunkielikeme
nash, tn
ampjunkielikeme
