F/S CDT Audio ES-02 BNIB
  • 2
bonesmcgraw
CDT Audio ES-02 2" hybrid mid/tweeter.
Brand new never used/installed.
CDT introduces ES-02 2" hybrid mid/tweeter incorporating a new parametric blend in an affordable package that puts, sweet midrange with incredible detail in your vehicle locations simply and easily. Suitable for enclosed or free air use in your vehicle, these hybrid drivers provide full, rich, extended midrange down to 150Hz up to a tweeter top end frequency of 20.000Hz. If you're listening tastes are for superior midrange detail with a sweet and smooth upper tweeter sound, these drivers provide optimum extended range, wider frequency range than any other driver in the market.
This new hybrid marvel is a unique 2" mid/tweeter, you get both mid and tweeter all in one driver (more and wider dispersion at the highest frequencies than any 25mm dome tweeter).
1 pr 2" hybrid mid/tweeter driver
Diameter: 2" (52mm)
Frequency response: 150Hz-20.000Hz
Sensitivity: 86dB
Power handling w/xover: 100W-150Watt HP
Magnet: Neodymium
Voice coil: 1.0" (25mm)
Surround: Rubber
Frame: Cast aluminum
Cone: Fabric/paper carbon reinforced
Impedance: 4 Ohm
Cone surround: rubber
Mounting depth: 1.26" (32mm)
The ES-02 hybrid is a unique 2" mid-tweeter speaker that can do jobs nothing else will touch. This driver is more extended and has a special hand coated cone and dust cap for assurance it will reach frequency response up around 20kHz.
The new designed ES-02 hybrid performs better power response (more dispersion at the highest frequencies than any 25mm dome tweeters). It can, however, reach 150 Hz at the low end although using it this low would be a power-handling problem. We recommend using it from 250Hz and up. Designed and built to deliver accurate and natural clean sound never heard before from a 2" driver.
$150 OBO
Included in price
[/url]
Many people have used them for a center channel and have said they work great. The best thing is there size makes it easy to fit in there and they play mid range all the way up.
bonesmcgraw
bonesmcgraw
United States
MAkahveli
    May 18, 2024
    May 16, 2024
