Sold F/S .::. Boston Acoustics SPG555 Blown Voice Coil
RetroAudioinc
Custom Car Audio Decals
These are S2 or S4 mine was a S2, you can pull the voice coil right out the front 6 screws it comes out. You can order a new one from Boston for $70 and it slides right in can be D4 or D2.
* 555 cm2 of surface area
* 3¾ inches of peak-to-peak excursion
* 3½ voice-coil
* Radialvent® cooling technology
* Only 26 Lbs! Thanks to Neodymium Lightweight design
* RVC™ (Removable Voice Coil) allows coil to be exchanged without removing the woofer from the enclosure
* SPS™ (Soft Part System) removable assembly enables field repair of the cone/surround/spider assembly
* Can be field-stripped and custom painted, powder-coated, or plated
* Work in multiple enclosures, both sealed and ported
* Integral sealing gaskets simplify both standard and inverted mounting
* Available in 4-ohm and 2-ohm versions
Price $200 brandnew sub with new slide in Voice Coil for $70. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
RetroAudioinc
RetroAudioinc
Indianapolis, IN
RetroAudioinc
