Sold F/S BNIB Fusion NV-AM25001 **$250**
massiveaudiocw
Selling this for my buddy, purchased this for his build but changed subs and need more power. Heared great things about these amps for the money, will produce rated power and hear they dont have a problem @ .5.
Specs -
Brand New Fusion NV-AM25001 Monoblock NV Series Amplifier
Bi-Metallic Thermal Venting System : Features two levels of heat dispersion through a combination of alloys with complimentary thermal transfer properties
One-Piece Cast Structure : This reinforced bi-metallic cast structure provides extreme strength, rigidity and protection in the extreme SPL ranges
Recessed Anchor Points : Robust industrial standard mounting feet with discretely recessed anchor points to provide clean, secure and resilient installation
Multiple Fuse Protection : Multiple fuses protect internal components and are easily accessible for quick changes in a competitive environment
825 Watts RMS x 1 Channel @ 4 Ohms and 1% THD+N
1310 Watts RMS x 1 Channel @ 2 Ohms and 1% THD+N
1790 Watts RMS x 1 Channel @ 1 Ohms and 1% THD+N
Max Power Rating: 2500
Max Current: 218A
Full Rated Power Distortion (Max) 1kHz: 0.43%
THD @ Rated Power 1kHz/100Hz: 0.3%
Frequency Response Hz (-3dB): 10Hz - 250Hz
Signal to Noise: >90
Variable Low Pass Filter: 24 dB/Octave
Bass Boost @ 45Hz: 12dB
Input Sensitivity: 0.2 - 8V
Input Impedance: 47K
Fuse Rating: 200A External
Pics -
$250 + Shipping - No trades - Price firm - Refs in my sig
Thanks,
Corey
is the 1790 at 16v?
From what Ive read 12volts.
I searched and found some of these things benching at
1153 Watts RMS x 1 Channel @ 4 Ohms and 1% THD+N
1717 Watts RMS x 1 Channel @ 2 Ohms and 1% THD+N
2283 Watts RMS x 1 Channel @ 1 Ohms and 1% THD+N
All at 12volts.
I dunno. If it were smaller Id take a chance.//content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
massiveaudiocw
massiveaudiocw
Upstate NY
SilverSquared
