Sold F/S AudioControl/Eclipse Head Unit
87grnissan
...................................................................PRICE DROP...............................................................................
I have a audio control dqs that is sitting around the house it is in very good condition and comes with box and manual. here are the specs on it.
Six Channel Digital Car Audio Equalizer
The DQS is a digital car audio processor that combines three high performance digital car audio equalizers in one compact chassis. The six inputs and outputs on the DQS make it ideal for surround sound car theater systems or when using source units with multiple outputs. Even factory installed systems will benefit from the DQS.
Six Input and Output Channels
Ideal for Car Theater Applications
Thirty Graphic Equalization Controls per Channel
Two Fully Adjustable Parametric Equalization Controls per Channel
Individual Level Controls
24 bit Digital Audio Processing
8 User-Programmable Memories
Input for Optional DDC Dash Control
160.00 shipped now 150.00 shipped
I also have a Eclipse CD8454 That is in good shape pulled from my daily vechical b/c i need money for bills, it comes with the knob remote and the credit card remote, cage trim ring and mounting ears, here are the specs.
The CD8454 can play CD, CD-R, CD-RW, MP3, WMA, and ATRAC3 from the Memory Stick reader, and it has a full AM/FM receiver and CD changer controls. If you are going to add an external amplifier or other outboard gear, you'll appreciate the very high eight-volt line output, which provides a stronger, cleaner sound. The built-in amplifier has up to 50 watts maximum into four channels, and there is an auxiliary input for listening to a portable audio device. This is a top-of-the-line system that enables anyone to get a fabulous sounding computer-tuned system.
The Eclipse CD8454 uses an incredible system to allow you to tune the system to the exact interior acoustics of your car. A "snapshot" of the frequency response inside your car is taken by the head unit and stored on a Memory Stick. Via a PC and the Internet, the Memory Stick can then connect to the Eclipse E-iSERV server that looks at your car's acoustic image, and it downloads the frequency and time delay information to optimize the sound. Place the Memory Stick back into the CD8454, and it will set itself up for proper playback. This is an absolutely brilliant way for anyone to receive a customized tuning
Eclipse CD8454 cd player, retailed for $690,... true audiofile head unit.
-8 volt rca outputs - front, rear, non-fading sub
-24 bit Burr-Brown digital/analog converter
-mp3
-aux input
-memory stick
-50x4
-eIserv
Specs: NOB Remote Control CD Changer Control CD-R/RW WMA MP3 Digital Servo System (DSS) TUNER STARTUNER® V Station Name Input AUDIO Output voltage and impedance 8V 55 Ohm MOSFET Amplification All digital circuitry 24-bit DAC DSP with Time Alignment, Parametric EQ, Crossover Electronic Crossover Control Non Fader Pre-out Dual Pre-out Digital Input Digital Output (for E-com) AUX In MEMORY STICK ATRAC3 Decode/Encode E-iSERV Connection Memory Stick ESN GENERAL ECLIPSE Security Network Display VF (Full dot) Full Face Tilt Bright & Dimmer Control ECLIPSE COMMANDER ADVANCE ready E-LAN data link system Current Drain 3A Dimensions (W ×H × D) 7" × 2" × 6-1/8" (178 × 50 × 155mm) FM TUNER Frequency Range 87.75 ~ 107.9 MHz (200kHz step) Usable Sensitivity 13dBf 50dB Quieting Sensitivity 14dBf Frequency Response 30 ~ 15,000Hz, ±3dB Stereo Separation 38dB (1kHz) AM TUNER Frequency Range 530 ~ 1,710kHz (10kHz step) Usable Sensitivity 20µV CD SECTION Frequency Response 20 Hz ~ 20,000Hz, ±3dB Wow & Flutter Below measurable limits Stereo Separation 85dB S/N Ratio (A-weighted) 100dB Dynamic Range 98dB Total Harmonic Distortion 0.01% AUDIO AMPLIFIER Power Output 13W x 4 (20 ~ 20,000Hz, 0.8%THD, 4Ohm) - MAX 50W x 4 Lineout Output Level/Impedance 8V(0dB)/55 Ohm Tone Control Bass +12dB at 80Hz Treble +12dB at 10kHz Loudness +10dB at 100Hz/+6.5dB at 10kHz MEMORY STICK PLAYER SECTION Frequency Response 20Hz ~ 20,000Hz, ±3dB S/N
175.00 shipped now 125.00 shipped
It is better and faster to call me on the cell phone b/c i am very busy and maynot beable to reply the same day you send a pm or post my number is 317-956-9332 name is jeff thanks
87grnissan
87grnissan
indianapolis
headbussaboi
