Item(s) for Sale: Audiobahn A1502dp class D amp
Class D, True Digital Circuitry 2-Channel Car Amplifier
RMS Power Rating:
150 watts x 2 chan. @ 4 ohms
300 watts x 2 chan. @ 2 ohms
450 watts x 2 chan. @ 1 ohm
Bridged, 300 watts x 1 chan. @ 4 ohms
Bridged, 600 watts x 1 chan. @ 2 ohms
Preamp Outputs
Cobalt Blue LED Illuminated Heat Sink Design (on/off switch for your preference)
Dual Cooling Fans
Chrome Flame Cooling Fan Grill Covers Included (other optional designs available and sold separately)
Double Sided Glass Epoxy Circuit Board
High Gloss Chrome Plated Finish
Optional Remote-mount Digital Volt-meter Display (Audiobahn ADM100T sold separately)
4-Way Protection Circuitry: Thermal, Short Circuit, Overload, DC Offset
Variable Bass Boost: 0-12dB
Variable High-Pass Crossover: 50-250Hz
Variable Low-Pass Crossover: 50-250Hz
Signal-to-Noise Ratio: 100dB
Frequency Response: 20Hz-20kHz
THD: 0.05%
Input Sensitivity: 200mV - 8V
4-gauge power and groud leads recommended.
Dimensions: 9-15/32" L x 8-1/2" W x 2-1/16" H
the amp has been fully tested, and it works great. ( i upgraded/rebuilt the power supply on this amp ) it is 100% working
I think that this is the coolest audiobahn amps they ever made.. its a digital class D, but it has the sound of a class A/B. it is super efficient and puts out more bass than you would think for the size it is....the amp lights up like a christmas tree!. a blue one!
it has some scuffs and scratches. one of the mounting legs is broke off. 3 should be sufficient to hold it down.... the heatsink fins have some dirt in them. but i will clean it up before it ships.. it will be bling bling !
The Audiobahn A1502DP 900W 2 Channel Digital Amplifier features includes - True Digital Circuitry that provide big sounds from a compact size and are perfect for a tight install!.
75.00 shipped to the cont usa..... no trades..
it will be packed up really nice... no worries
RMS Power Rating:
Preamp Outputs
Dual Cooling Fans
THD: 0.05%
