Sold f/s Atomic 5000.1, Atomic APX motor and APX-10
hazardous0388
Alright, time for a new thread. beacause i had a few things come up all of this has to go and go now.
First up is an Atomix APX motor with 10 inch basket. will come fully assembled so nothing gets in the pole. just needs a recone. SOLDD
Next up is a fully working Atomic APX 10. Was originally purchased direct from Atomic from myself. It has dual 1.4 vc. Price on this baby is going to be $250 shipped.
The left sub is the motor alone sub and the right is the fully working sub.
Last up for sale is my Atomic 5000.1 amplifier. I also purchased this through Atomic direct a lil under a year ago. Very powerful amplifier here!!! Price on this baby is going to be $750 shipped.
NEED These THINGS GONE!!!!! PM OFFERS!!!!
Thanks Sir. keep me posted on when you turn that motor into. i wanna hear the new setup when you get it done.
Most def! I need to figure out how much power I'm going to run first, and if I'm gonna make her a dedicated spl sub or a daily ground pounder:p:
* Digital mono block amplifier
* Dual MOS-FET power supplies
* Efficiency over 86%
* RMS power handling---1500w @ 4 ohms @14.4V
* RMS power handling---3000w @ 2 ohms @14.4V
* RMS power handling---5000w @ 1 ohms @14.4V
* Signal-to-noise ratio 90dB
* Phase shift 0-180 degree
* subsonic filter: 10-60Hz
* lowpass filter: 35-300Hz
* Input sensitivity: 200mV -6V
* Bass remote controller with telephone wire & click volume & blue LED
* 3 way protection: over voltage, speaker short & thermal overload
* Total harmonic distortion:
* Continuously variable 0 – 18dB Bass Boost
* Built - in variable 0 – 18dB per octave x’over
* Power Consumption
http://www.atomicspeakers.com/5000d.html
it's a very efficient amplifier. This thing puts out crazy power too. this amplifier clamped almost 4700 watts @ 11.4v wired at 0.35 ohm. If you run it at 1 ohm daily and keep the voltage up then you will have no problem getting 5000 watts out of it....considering they rate it at 14.4
amp still perform good? looks roughed up....650 shipped to 47725? let me know, thanks
amp still works fine. and quite a few members on this forum know it works just fine. my already have a buyer for $700, but if i would to take the $650 offer you would need to cover the pp fees.
also, the amp only has one real cosmetic issue and i will actually attempt to get it off today via mineral spirits.
hazardous0388
hazardous0388
Springfield, MO
hazardous0388
