extruded ports
You are talking about external ports, correct? Having the ports on the outside of the box is a good thing //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
pressure should be different outside of the enclosure compared to inside the enclosure so this could be a factor if the port isn't secured inside the enclosure. For instance if the pressure inside the box is really high and the port is long and only held by 4 screws, it could "ring" or vibrate. I don't know if this affects anything, but its possible. outside the box the pressure around the port would not be has strong so this should not be a problem. I always wondered this when I made boxes with aeroports, but the boxes sounded good so I didn't give it too much thought.
Basic airflow. With external ports the air doesn't need to circulate around them inside the box. Make for an easier in/out flow. External ports also helps with loading against panels & corners inside a vehicle without having the box really close to those panels blocking air flow.
Savag3
sav'd out
Savag3
Central KillaCali
roarzorz
