external aero's to port a sealed box??
well the box is for my idmax... i didnt really think it mattered rather it was a slot port or aeros. Does an aero produce a different sound than a slot?
I have the idmax in 2.5 sealed and i like it a bunch, i would just like to try it ported and sealed before i build a nice box for it.
well using that, for a 2.5cuft box @32hz i would need 1 4"x11.3" flared port..... Doesnt really make sense because i can also use a 2"x2.84" flared port
what about that doesn't make sense? they have the same port area...
2^2(3.14)= 12.56
1.42^2(3.14)= 6.33(2)=12.66
if you have the length i would go for 2 3" aero's.
is there any possible way for someone to suggest the correct size aeros to tune a 2.5cuft box to 32-38hz if getting any lower than that is a problem?
1 4" aero or 2 3" aeros. psp's calculator works perfectly. You'll have a bit more port area with the 2 3's, but either will work.
11" long 4" port will get you 33hz. Perfect.
budahbuddy803
budahbuddy803
Aiken, SC
yunvme666
