Extend Power Wire?
How short is it? You could add an inline fuse holder if the location allows it.
That is what i was thinking of. You may be able to rig something up using the casing of the fuse..
x2 on the fuse idea.. unless its under the carpet..
you can use maybe a reducer or maybe a t block. or you can use some heat shrink and a couple gnarly connectors. you will need to find some monster ratcheting crimpers though. you will want to solder with a torch as well.
dont be ghetto...
http://cgi.ebay.com/Stinger-4-Gauge-Power-Wire-Coupling-Coupler-SPT5211-HPM_W0QQitemZ170141394547QQihZ007QQcategoryZ50549QQcmdZViewItem
You could put a ring terminal on the end of the existing wire and the beginning of the new wire, overlap them, and put a nut/bult through them to keep them together. Kinda ghetto, just get the stinger thing.
*X'S~2*...Perfect/:).Not raggin' on you,but...Always buy a few more feet than you need(For Bends/Curves/Dips) when you're routing the Cable.Plus...if you decide to sell your car down the pike..take it out,as it may be useful in your next car/:) .\\I would *Definately* use Dual Wall Adhesive Shrink Tubing on that splicer piece...For Sure!!(Can be had on E/Bay for not much $$$...//
Just a thought & some help.Best of Luck w/your System.
Kind Regards/
Raymond
vewbvye818
vewbvye818
ny
MustangGT25YRS
