Looking to trade this stuff toward TI BASKETS. Let me know what you want.
Item(s) for trade:
16 Pyle Pro 6.5" woofers PPA-6
4 Pyle Super Pro TI PDBT45 SUPERBULLET Tweeters
Specs for woofer:
150 Watts RMS/400 Watt Peak
Sensitivity (1W @ 1M): 88.5 dB
Frequency Response: 60-7 KHz
30 oz Magnet
1'' Kapton Voice Coil
Stamped Steel Basket
Strong Black Paper Cone
Cloth Edge Suspension
Bumped & Vented Pole Piece
8 Ohms Impedance
Specs for Tweeters:
Cloth Diaphragm
400 Watts Max./ 1.75" Voice Coil
15 Oz Magnet/ 4~16 Ohm
4.45'' Diameter - 3.25'' Mounting Depth
1500-20,000Hz/ 104dB/ w/ m
All BNIB
woofers are 8 ohm
Tweeters are 4-16 ohm ( 8 with 8 ohm resistor ) Though im not sure if they have the resistors or not. Was told newer models didn't come with it so they'd be 8 ohm.
Audiopipe APSM-4050 BNIB
BNIB, just don't need it as I got rid of my other audiopipe stuff. Selling this to finish current build for late summer early fall.
Specs:
• 4x50W RMS@4 Ohm (
• 4x80W RMS@2 Ohm (
• 2x150W RMS@4 Ohm
• Frequency Response: 5Hz - 30kHz
• S/N Ratio: >80dB
• THD:
• Input Sensitivity Level: 0.2V - 6V
• HPF: 50Hz - 1.2kHz
• Dimension (LxWxH): 201x154x49mm ( 7.9x6.06x1.9 ) in Inches
1 JL Audio J2 1000.1 amp
BNIB
Specs:
J2 1000.1
Rated Power 14.4 V: 400W x 1 @ 4 ohm
700W x 1 @ 2 ohm
1000W x 1 @ 1 ohm
THD at Rated Power: 1% @ 4 ohms
Frequency Response: 10 Hz - 160 Hz +/- 0.5 dB
Input Range: 200mV - 6.5VRMS (Low-Level)
630mV - 20.5 VRMS (High-Level)
Dimensions (L x W x H): 14.60" x 9.60" x 2.15"
(371 mm x 244 mm x 55 mm)
Item(s) for trade:
Specs for woofer:
30 oz Magnet
8 Ohms Impedance
Specs for Tweeters:
Cloth Diaphragm
All BNIB
woofers are 8 ohm
Specs:
• 4x50W RMS@4 Ohm (
• 4x80W RMS@2 Ohm (
• 2x150W RMS@4 Ohm
• S/N Ratio: >80dB
• THD:
BNIB
Specs:
J2 1000.1
700W x 1 @ 2 ohm
1000W x 1 @ 1 ohm
