EQ/Processor
dnosryd
I've checked the search and it wasn't really any help so a few suggestions would really be appreciated.
Okay I have an Alpine CDA7995 and I really like the unit but I want to add some type of EQ/Processor to tailor the sound a bit more than the 2 band parametric on it now. I have a clarion 5 band EQ but if I use it I can only use 1 preout so I'll lose the time alignment and bass focus features besides the clarion kicking up the voltage to 7V where the Tsunami amps I'm running are 6V max. What I'm looking for is something that has a 6 channel in/out so I can control front/rear/subs separately. Also if it has a line driver of some type would be even better because I'm finding out now that the sub out on the Alpine is nowhere near 4 volt as I have to run the gain kind of high to compensate.
Any suggestions are appreciated.
id like to get a eq/line driver for my system but i am relatively unfamiliar with line drivers. i know that most amps cant handle more than 8 volts. that model that you recommended is rated at 13.5v. will that number decrease by the time it reaches the amp(s), or do you just need a high end amp. right now i have a JL 500/1 and i will probably end up buying either a JL 6 channel or a 4 and a 2 channel.
dnosryd
dnosryd
paramount, ca
worm
