Wary
Just installed a Kenwood DNX-8120 deck, the double din 5v.
I have Zapco 4.0 C2K, and the Zapco 9.0 C2K amps which I used their symbilink for the balanced line system. The 4.0 to BA Z6's for the fronts and the 9.0 to 2 JL 12w7s.
I really want to install my Audio Control Epicenter on my subs but I wonder if that will really mess with anything? Has anyone else installed an epicenter on a balanced line system? Does it have to be Zapco compatible?
I'd have the RCA sub-out on the deck running to the Epicenter, then to the SLB-U transmitter for the volume control knob and balance line then out to the 9.0. Any settings I'd need on the Epicenter?
Anyone advise against it? I should probably just try it but I thought I'd ask first.
I just took out my SXSL-II because I thought the Kenwood can do it all.
this is what my installer said
"Epicenter has to go on a full range channel so if you're going to use it make sure you don't use the sub low pass crossover in the deck and use the one in the amp. I don't know if it's really necessary given all the power and sub you have... It can be a sub killer. So just be careful!"
I want my Epicenter! lol
