vehementSPL
Well As it says. Like say I am using one end of the box as part of the port. I know end correction and how it works. But there is a question. If I was to screw a piece of wood there the same length as the rest of the port, how thick does this wall as where end correction is no longer an Issue. Like for example (I know not possible) but if the port wall you used was 1/1000th of an inch thick it wouldn't affect the end correction most likely I would think. The theory in question is assuming you are using one end of the box and just attaching a piece of wood to the side of the box that is using the box as part of the port to just create a port the same length as the rest of the port without end correction. I have approx 500 inches of port and obviously don't want to shrink it due to lowering the tune. the port is 12h x 41 high. the origional port design was 4 inches deep. but used 3 sides of the box as port. Top/two sides. Port is all the way across the top of the box. I am trying to tack 3/4inch mdf to the box all the way around the inside 4 inches deep. To make the total effective port depth truely 4 inches and not 10. I am thinking 3/4 would be enough. But surely there would have to be a thickness where it wouldn't affect end correction. There will be NO distance between the port walls and the side of the box. There will just be a 3/4 inch thick strip tacked on the side of the box. I would think this would work... .But for some reason doesn't seem right to me... not enough width from the side wall..... or perhaps I just have questioned it so much that it doesn't look right
