Elemental Designs 10A.22 vs Pioneer TS-W2502D2
wilson_gau
Which one will perform better?
Also, I have a T1000.1. Will that amp overpower (blow) the sub? If yes, then I might need to get another amp for whichever sub I use..
Thanks for any input!
On the other note: I am planning to get Lanzar MAXP1200. I know that the lower level amp, but it seems bang for buck (30Ax3 fuse ~= 1000w RMS for under $75). Can anyone give input why I should NOT take it or is that the best amp under $100?
I would stay with the T1000, it will put out cleaner power and you will just have to be careful with the gain. You are better running a stronger amp at a low setting, rather than getting an amp less than or equal to the speaker's rms rating and running it maxed out. I doubt the Lanzar will do rated but it will get pretty close.
wilson_gau
wilson_gau
Seattle, WA
wilson_gau
