Electric Scooter Question
i cant find a pic of it, but it looks similar to this....and it runs
just make it so when it turns the weed wacker it just turns your wheel, and wire up the throttle to where when you pull it it goes faster...
I used to sell both electric and gas powered scooters in that exact same body style, if you can figure out a way to mount the motor it is done easily, be prepared to pay $$$ for the chain though, its #20 chain IIRC and is like $40 for enough for 1 scooter w/ connector links.
its honestly not worth it
If you do use a weedwacker motor make sure it has a clutch on it. The cheaper models don't. To tell try to turn the end where the string attaches, if it spins freely it has a clutch and can be used, it it turns the motor it doesn't.
Also, you will have to figure out how to make a shaft that connects a gear to the the clutch shaft. It will require some fabrication, unless you can find a clutch drum that already has the gear on it.
Don't waste your time.
If you had to come here and ask how you don't have the skills and probally not the tools to do a custom install of a gas motor.
It's going to take your own research, fabrication and trouble shooting
CrispedUp
CrispedUp
The Jungle
AVSTANG02
