Efficient / non efficient amps
efficient
adj 1: being effective without wasting time or effort or expense; "an efficient production manager"; "efficient engines save gas" [ant: inefficient] 2: able to accomplish a purpose; functioning effectively; "people who will do nothing unless they get something out of it for themselves are often highly effective persons..."-G.B.Shaw; "effective personnel"; "an efficient secretary"; "the efficient cause of the revolution" [syn: effective]
inefficient
adj 1: not producing desired results; wasteful; "an inefficient campaign against drugs"; "outdated and inefficient design and methods" [ant: efficient] 2: lacking the ability or skill to perform effectively; inadequate; "an ineffective administration"; "inefficient workers" [syn: ineffective]
I pity the fool...
//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Alto Mobile amps I believe are the most efficient amps on the market- they claim they 'exceed 90%' in that dept...full range class d's
the work efficient may be an adjective, but 'Efficiency' of an an amplifier is based on technical data..
http://www.altomobile.com/html/amplifiers.html
I don't know though.......CA&E mag just did a test review on one of them and it had significant top end rolloff begining at 7khz........
Eclipse however also has a full range Class D amplifier.
I thought it was 17Khz?? Maybe that was the -10dB. I was actually thinking of purchasing the Altos until this review. Even the listening session can't sway my vote with that SAD measurement. The Class G Genesis looked appealing thoug, aside from the ridiculous price tag.
And while I'm at it. . . . .
Guess where the breeding ground for stupidity lies. We're all close right now. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Massive Audio's A/B's are great, over 70% at full power from my RS-100
If you want 1 amp to power your component and subs efficiently then look into Avionixx 800.4 class T
It was -1db at 7khz, -3db ~11khz, and only got worse from there......
Yeah, I just read that. You made me go get the mag. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
//content.invisioncic.com/y282845/emoticons/bsflag.gif.21f42eccd34b7d1eb1608fb1b59b69c3.gif
You might see A/B get into the 70s at full output, but efficiency is usually half that at 1/3 output ...
Class D and Class T/X amps are typically the most efficient, with efficiency at full output between 60-90% with a small drop in efficiency as power decreases ...
Me = misreader of stuff
http://www.caraudiomag.com/specialfeatures/0111cae_anatomy/
Your mother is an IDIOT....Look it up, ask an English teacher, the word efficient is an opinion! NOT A FACT.......
The ratio of the useful energy delivered by a dynamic system (such as machine, engine, or motor) to the energy supplied to it over the same period or cycle of operation. The ratio is usually determined under specific test conditions.http://www.natresnet.org/resources/lender/lhandbook/glossary.htm
The measure of loudspeaker's ability to convert power to work. Formula Efficiency = (power out/power in) x 100. Efficiency is always expressed as a percentage.
http://www.precisionautosound.net/glossary.html
The ratio of total output power to input power expressed as a percentage. Normally specified at full load and nominal input voltage.
http://www.snaptec.com.au/technicalnotes/glossary.htm
The percentage of power that gets converted to useful work. Example: An electric pump that is 60% efficient converts 60% of the input energy into work - pumping water. The remaining 40% becomes waste heat.
http://www.thesustainablevillage.com/essays/watpumpglossary.html
The ratio of the output to the input of energy or power, expressed as a percentage.
http://www.canren.gc.ca/prod_serv/index.asp
The efficiency of a transformer is the ratio of its power output to its total power input.http://www.jeffersonelectric.com/techglos.html
Generally speaking, efficiency is the ratio of total energy output to total energy input, expressed as a percentage. Loudspeaker efficiency is usually very low, in the 1% to 3% range, meaning 97% to 99% of the energy is dissipated as heat! A typical car audio amplifier has an efficiency of 50%. Rockford Fosgate amplifiers efficiency ranges from 50% to about 70%, which means less current drawn from your electrical system for a given amount of power than our competitors.
http://www.customautosounds.com/faq.html
Hmm... //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
SteelWheel
SteelWheel
Hattiesburg
Nikuk
