eDead Chronicles...turning blue
Strecker25
Better than everyone
well i got 2 gallons of v3 as part of the group buy, and im covering as much of the lumina as possible. Starting with the trunk, moving to the rear deck all 4 doors then whatever is left (if any) to other areas. Heres a few pics from today, ive now got 3 coats on the trunk (EVERY piece of metal is covered, including all the way up the side walls and under the rear deck)
Couple coats on front door.
One coat on the rear door, first coat is the toughest to get to stick.
Heres inside, Dynamat-xtreme covers the rear deck, and ive made my way up the window pillars to the edge of the headliner.
Heres a progress shot from the back, trunk lid also has a decent 3 layors on
Ill update as i make more progress, 1-2 more coats on each door are planned, hittin the rear deck and pillars again, and maybe reinforcing the trunk again. I have about 1.25 gallons left so well see how far i go..let me know how it looks!
btw thank you very much for the coordinators of that edead coupon 2 gallons only cost me 100$ shipped //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
nice work. What do you think of the stuff so far? I plan to do the same thing to my truck.
well i cant give a real review, but just by tapping panels which are very thin i can see its noticably deadended them. Ill be sure to let give a nice review on it once its installed. Definetly has already lowered some road noise coming from the trunk.
and no it is defiently not comin off
can that be used for the inside of your door panels? i have major rattles from my door panels.
i used it on both panels,inside and the outside wall and ive also coated the backside of the actual door panel with a couple layers also.
Heres an update for today if anyones interested..
Finished off the trunk, unless i have some left later.
Heres the finished front door.
Heres the rear deck, it now has a layer of dynamat extreme and 3 layers of v3
Heres the back of the front door panel, since ill soon be glassing an enclosure for my mids over it i decided it should help
overall i can already tell a difference, the door shuts so solidly now and i can knock it and barely hear it on the inside //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
well since it was cold as hell otu and my dad didnt want the garage heater running all day i decided to do all of the plastic trim pieces on the inside.
heres my other project, its about 4 feet long and runs on nitro //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif hope to have it painted and running upwards of 50mph by spring time
Strecker25
Strecker25
Rochester, NY
Strecker25
