eD Nine.1
Astyl
Car Audio Enthusiast
So, whats the word on the eD Nine.1? Is it a good amp? Im looking for a amp to power the ever popular, 15 inch type R / TCAB Combo.. Basically i dont wanna go hifonics, because theyre overrated and i might run into problems with setting the gains, yada yada yada..
All i really wanna know is
1. Does the nine.1 put out 1200 TRUE WATTS @ 1 ohm, as its rated at, and isent overrated like hifonics?
2. Is it a good / reliable amp?
nine.1's are very solid amps. I used to run two of them last summer.
I think the type-r would want more power though.//content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
fyi, I don't think there should be any difference setting the gains on a hifonics amp
In theory, there should be
You set your gains according to the mathematical equation way..
IE 40 watts x 4 = 160 / sqrt of that number = your voltage needed
Hifonics are overrated amps, meaning they dont push the power that theyre rated at
The only thing you have to go on when setting a gain on a amp is its RMS rating
So lets say i buy a hifonics amp thats rated at 1600 watts, but its OVERRATED, so it dosent put out anything near that.. so now i set my gains to 1600 watts because thats "the thing to do" , well now your clipping your amp because its not meant to put out that kind of power
ide rather set it to true watts instead of clipped watts
If you would have searched, you would have found quite a bit of information.
The 9.1 also comes with a three year warranty- if you buy a used one, or sell yours, the warranty transfers. $350 shipped new, obviously less used.
I owned one, had no problems.
Astyl
Astyl
Bedford, NH
tmoney
