**I'll get some pictures of all of my stuff by weeks end**
1 Illusion nd8 – $75 shipped
http://www.illusionaudio.com/docs/carbon_rd.htm
The ND8 is an awesome woofer with a mounting depth of only 2.2”. I was going to run this one as a midbass but I couldn’t find another one. It will probably serve well as a slim front sub. The link is for a newer version but they are similar.
Seas P17REX - $75 shipped
http://www.seas.no/seas_line/woofers/H416.PDF
The closest Seas midbass that you’re going to get to the Seas L18/CA18 series with a 2.75 mounting depth
Crystal CSM 410 4" Midrange Speakers $30 shipped
Woofer 4" (101mm) Beaded Paper Cone Peak Power Handling 100 Watts RMS Power Handling 50 Watts Sensitivity 90 dB Impedance 4 ohm Frequency Response 120Hz - 21KHz
They bested the Hi-Vi B3N and Aurasound NS3 (b/t 160-3000Hz) but that is probably because of their size and wattage advantage. They sound awesome free-air.
Sony XEC-1000 5-way electronic crossover w/ printed manual - SOLD
Inputs – Total 3 pairs of gold plated RCA jacks
Sub Woofer Rear Front
Outputs – Total 5 pairs of gold plated RCA jacks
Sub Woofer Rear-Mid Rear-High Front-Mid Front-High
The subwoofer channels have an on/off selector, stereo/mono selector, analog low boost (40 Hz, 0 to +10 dB) adjustment, Low pass filter selector (180, 120, 80, or 50 Hz), +/-phase selector, and analog level control
The rear-mid and front-mid channels have an analog mid cut (180 Hz, -10 to 0 dB) adjustment, Q selector (6, 3, or 1), Hi-pass filter selector (180, 120, 80, or flat Hz), Low-pass filter selector (flat, 5k, 3.5k, or 2.4k Hz), and analog level control.
The rear-high and front-high channels have an on/off selector, +/-phase selector, Hi-pass filter selector (7k, 5k, 3.5k, or 2.4k Hz), and analog level control.
OZ-25 Tweeters & PX-41 Crossovers - $35 shipped
These are from an old school series set. The PX-41 crossovers are built for the 4” midrange but the tweeters are the same for all of the different sizes. Tweeters domes look a little sun bleached.
Pioneer Premier GM-X402 - $40 shipped
A-Class (purple) amplifier. Continuous Power: 35W x 2 @ 4 Ohms (20 - 20,000 THD= 0.08%) 80W x 1 @ 4. This amplifier would be great for tweeters and mids. Cosmetically 7/10
Planet Audio TT4200 - $115 shipped
A/B-Class amplifier, which I believe was one of the last ZED built amplifiers for Planet Audio. 4x50 Watts RMS, 2x200 Watts RMS, 2 ohm stable. It kicked the **** out of my Rockford 550x so I am guessing that it puts out more then 4x65 Watts RMS. Cosmetically I’d give it a 5/10 because of some heavy scratches on the top.
AutoTek Street Machine SX-1700 w/ Remote- $250 shipped
Pre DDI D-Class amplifier.
1 x 400w @4ohm, 1 x 700w @ 2ohm, 1 x 1200w @ 1ohm MONO
- Full MOSFET circuitry. - Fully adjustable X/Over. - Regulated power supply. - High current amps. - True 1 Ohm stability. - 0-18 dB variable bass boost @ 43Hz. - Adjustable line outputs. - Therma-Cool heat sink design. - 4-AWG molded terminals. - Chrome-finish heatsink. - Chromed front & end panels. - Maxi Fuse.
Cosmetically 9/10
eD 130v.2 dual 2 ohm Subwoofer w/ original box - $165 shipped
http://edesignaudio.com/product.php?cid=2&cur=USD
Good all around sub SQ/SPL wise. Can be used in IB installs, 600-700 Watts RMS, Sealed 0.6-1.1 / Vented 1.2-1.5
1” MDF box for eD 130v2 - $15 + shipping
Positive gold battery terminal 0/4/8/8 awg input/outputs - $5 shipped
Cosmetically 9/10
