eclipse sw8200 lnib
some info that was posted by another member on caco.
S3 coil, Heres TSP's
Re = 3.2856 ohms
Fs = 22.0150 Hz
Zmax = 23.5699 ohms
Qes = 0.9382
Qms = 5.7920
Qts = 0.8074
Le = 1.0685 mH (at 1 kHz)
Diam = 256.5400 mm ( 10.1000 in )
Sd =51689.2299 mm^2( 80.1185 in^2)
Vas = 87.1135 L ( 3.0764 ft^3)
BL = 10.5028 N/A
Mms = 227.7101 g
Cms = 229.5200 uM/N
Kms = 4356.9180 N/M
Rms = 5.4381 R mechanical
Efficiency = 0.0931 %
Sensitivity= 81.7071 dB @1W/1m
2.1 sealed on 700 is fantastic, curtain shaker from Bassotronics is audible and usable. The box chokes it a little but helps with tightening it up a bit and helping output above 50Hz. Larger boxes extend the f10 shelf but at the cost of power handling. Awesome subs for those looking for output in the teens.
  • Locked
COMPLETED WTB Eclipse SC8365
I checked at Diyma and I signed up for an account but I cant post in the classifieds. Thanks for the tip, I'll keep a check there.
I have a couple 3000s and 5000s and cant remember the other two right off hand, but these will not work with your unit that I can think of by...
877
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
xxxbasshead
xxxbasshead
lake forst , ca
xxxbasshead
    May 31, 2024
    May 24, 2024
