Eclipse reading SEC Disk
found instructions:
1. Turn the vehicles ignition on and press the power button or the FM-AM button (make sure the tuner is on). 2. Press and hold the radio station preset button 1 and the FM-AM for more than one second. 3.Once the display flashes [disc] insert the key cd you selected to activate the ESN. The display should now read [CnCl]. The ESN is now deactivated.
To resume normal operation after the power has been disconnected to the unit:
1. Wait for the dispaly to read [disc]. 2. Insert you key cd, if the correct CD is inserted your display will read [---] and the cd will begin to play. If the wrong CD is inserted it will display [Err]. If you insert the wrong CD 5 times it will say [call 800] and then you have to send the unit to eclipse to have it rest. Good Luck!
How to read the Electronic Serial Number:
1. Turn the vehicles power on. Prss the FM-AM button. 2. Press radio preset button 4 and the FM-AM button for more than a second and the display should show your 8 digit serial number. This number is to identify your unit if it is recovered after being stolen. Yep, that will happen!
brmcm15
Oh lawdy!
brmcm15
Macomb, Michigan
Horsemanwill
